Old 16-02-05, 02:23 PM   #1
Barty_b0y
Default airblade double bubble
Any one got one
Couple of questions
How do they wear - are they prone to scratching easily
Are they rigid - do they have a strenghened bit at the back of the screen ?? like the originals ??
@ 37 quid off ebay without going else where its not bad money
but im an avid beleiver of " if somthing to good to be true it probably is "
so are they any good ????
thanx by the way
Old 16-02-05, 02:27 PM   #2
Ceri JC
I got one for a similar price and I'm v. happy. One of the least pronounced "bubbles" I've seen (more noticeable once it's on the bike).
Good fit and looks well good though
Old 16-02-05, 03:46 PM   #3
Grinch
I've got the same.. though I had a bit of trouble fitting it on me 2001 s model, needed to file the holes a little 'bigger'. If you look after them then they do last, though mine has scrached a bit due to winter riding and 'grit'.
Old 16-02-05, 04:11 PM   #4
mattSV
mattSV's Avatar
I had an airblade on my 650.
Like a few others, it didn't line up too well when fitting it, but once it was on there it looked good.
No issues with the finish (had it on for about 2 years I think).
At £37 it is worth taking a chance!
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 16-02-05, 04:25 PM   #5
Iansv
No probs with mine apart from initial fitting being a little fiddly
Old 16-02-05, 04:29 PM   #6
BaggaZee
I had one crack when fitting it in extreme cold. Warmed the next one up and had no problems. Doesn't have the ridge that the original does but seems to do the job & finish has lasted no problem (irridium one).
Old 16-02-05, 08:54 PM   #7
Big Bad Al
Big Bad Al's Avatar
Yeah I though it was the same profile as the orig screen, but once fitted it does the job really well. Thing that puzzles me is I didn't have to bend it to fit it but it looks more pronounced now....
Nice screens but the inner fairing needs cutting down on the screw holes near the top or you get a gap. If you look in the bodywork section there arepicture showing the gap I'm talking bout.
SFV650 in black with Evotech tailtidy, R&G Aeros and Heated Grips, Puig fly screen, Pipe Werx GP style race exhaust. Whoop!
Previously.... Black SVS - DHM's Heated Grips Airblade Iridium Double Bubble Screen Beowulf end can and Evotech tailtidy. 3/7/2004 - 26/6/2015.
Big Bad Al is offline   Reply With Quote
Old 17-02-05, 11:10 AM   #8
Captain Nemo
got one on an 04, no probs you need to trim back the top screw in points on the inner fairing(i used a stanley knife) or there will be a small gap at the top between the inner and outer fairings, but apart from that its a good fit, better than the original for lifting the wind blast but not as good as the screens with a bigger bubble, although ok at the speeds the sv does.
looks noce too at £37 you cant go wrong i piad £54 for one in dec/04 direct from powerbronze.
Old 17-02-05, 01:00 PM   #9
Barty_b0y
k chaps thanx and noted
Double Bubble to fit K5 sauluk Stuff Wanted 10 12-03-09 02:11 PM
Double bubble K5 Ward8124 Stuff Wanted 2 16-01-06 08:32 PM
double bubble in red zx6man SV Talk, Tuning & Tweaking 1 02-03-05 01:19 PM
Airblade Iridium Double bubble Big Bad Al Bikes - Talk & Issues 13 25-01-05 11:34 AM
Double Bubble Steve H SV Talk, Tuning & Tweaking 5 19-01-05 07:27 PM
