Old 08-03-05, 03:41 PM   #1
kern0079
Default Regulator/Rectifier testing charts
I need someone with a 2002 SV to send me a chart out of their repair manual. I am looking for the chart that gives what the measured voltages from the reg/rect.
E-mail at kern0079@umn.edu
Thanks
Old 08-03-05, 03:47 PM   #2
Flamin_Squirrel
Are the ones on this site no good? http://www.sv650.org/sv_manuals.htm
Old 08-03-05, 03:54 PM   #3
kern0079
I know that the reg/rect for a 2002 is different than those for the 99-01. As far as I know it is just the plug configuration but I am trying to confirm that before frying my electrical system. The link you posted only gives the chart that applies to the 99-01 reg/rect.
Old 08-03-05, 04:17 PM   #4
Flamin_Squirrel
D'oh, my bad. Thought it was worth posting just in case though
Old 08-03-05, 07:51 PM   #5
Hmm? I've got a 2002 one in the garage and it's interchangable with my '00. Do you mean you have aan injected (ie 2003) bike?
Old 09-03-05, 03:17 PM   #6
kern0079
No, I mean the 2002. At some point in 2002 the bikes began using a different plug setup on the reg/rects and I want to ensure that it is just the plugs that changed before I install a 2002 on my 2001.
Old 09-03-05, 03:23 PM   #7
Fair enough... Like I say, i've got one which came out of a K2 which is identical to my old one, but maybe they changed during the year.
Old 09-03-05, 06:02 PM   #8
kern0079
It looks like the K3 uses 2 plugs, why the switchover for a short time in the k2's I wonder? Someone is messing with my head.
Old 09-03-05, 11:03 PM   #9
That's why they did it
Old 09-03-05, 11:19 PM   #10
Mike1234
There are lots of things that found their way on to the late K2s and early K3s that were a bit, er, unusual.
The late K2s had the same crank cases as the K3s so it is possible to add an oil cooler fairly easily.
The early K3s had a 22mm centre steering stem as per the earlier bikes but changed to a 24mm one for later K3s and beyond.
It is entirely possible that the regulat for a late K2 is the same as that for the K3 models.
regulator rectifier K5 Pam SV Talk, Tuning & Tweaking 2 07-02-09 08:43 PM
I need a Rectifier / Regulator. Marv Stuff Wanted 3 19-08-08 12:43 PM
Rectifier/regulator Gordon B Stuff Wanted 12 02-01-08 11:00 PM
Where to buy a SV regulator/rectifier? falc SV Talk, Tuning & Tweaking 8 17-08-05 09:43 PM
Regulator/Rectifier Steve T SV Talk, Tuning & Tweaking 3 10-10-04 10:34 PM
