Old 15-03-05, 10:46 AM   #1
Ceri JC
Default Squeeky rear brake
My back brake has just started (fairly suddenly, was fine till this weekend, now does it consistantly) to squeak when it's used to bring the bike to a standstill (ie from 10-0mph). It's not squealing, nor is it locking up. The brake "feels" fine in that it's as responsive as usual, so there doesn't appear to be anything wrong with the performance of it. Do I need to clean my pads? Any advice greatly appreciated as it's getting on my nerves
Thanks.
Old 15-03-05, 10:47 AM   #2
Carsick
It's probably just the pads moving against the mountings.
Taking them out and putting some copper grease on the back is apparently the solution.
I left mine, I tend to wear earplugs so it doesn't bother me.
Old 15-03-05, 10:50 AM   #3
Cloggsy
Mine started to do this... Remedied as above
Old 15-03-05, 11:18 AM   #4
Ceri JC
Thanks folks. Due a service soon, do you reckon it's worth asking them to have a look at it while they've got it (never removed the brakes before- I tend not to tinker with "life threatening" bits )?
Old 15-03-05, 11:20 AM   #5
Cloggsy
I'm was of the same opinion, so I got a mate around who knows his stuff... It improved my confidence no end... It isn't rocket science, honest
Old 15-03-05, 11:25 AM   #6
Iansv
both my brakes squeak... i've not braved tinkering with them
Old 15-03-05, 11:27 AM   #7
Cloggsy
Too much time in here, thats why 11,000+ posts
Old 15-03-05, 11:29 AM   #8
Iansv
nah, inconvenient shifts that mean I get no time in the daylight.... and lazy weekends...
should get the haynes out really, but I can put up with it anyway
Old 15-03-05, 11:39 AM   #9
Ceri JC
Yes, I'd like to learn to do more stuff like this. I've got a few mates who are trained car mechanics who I use for advise on things like this, but I'd like to have a biker whose done it before handy. Am I right in thinking you don't need to remove hoses/bleed the brakes in order to take the brake mechanisms off? With the grease on the back, is that the back of the pad (eg not where it touches the disc!)? Thanks folks.
Old 15-03-05, 11:51 AM   #10
Scoobs
No hoses have to be touched.
Remove the caliper from the forks.
Remove the retaining pin. The one with the R clip through it.
Remove the pads.
Clean them up. There will be a thin metal clip on the back of the pad. Take this off and clean that up as well.
Replace the metal clip. Copper grease on that side, NOT the friction material side.
Reassemble.
It is an easy job (really) as long as the retaining pin ain't seized in the caliper. Before replacing the retaining pin a bit of hi temp grease to stop it seizing is advisable.
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
Squeeky rear brake rich_r SV Talk, Tuning & Tweaking 5 27-03-07 01:05 AM
how to cure a squeeky rear brake ?? oldsvrider SV Talk, Tuning & Tweaking 19 23-08-06 07:51 AM
Squeeky rear brake!!! Robchelt SV Talk, Tuning & Tweaking 7 09-08-05 12:11 AM
