Old 28-04-05, 12:50 PM   #1
The Mass
Default Scottoiler MK7 Touring Kit
HI all,
I may have mentioned this last week to all on the S.Wales rideout.
So I had an "Issue" with my Scottoiler, and thinking to myself that the rear sprocket is looking a little dry.
After piddling about whith the settings and taken on board Carsick, Fizzwheel and other advice. I have had a good look at all the documentation and PDF's (cheers Cloggsy )
And have now gone as far as to speak to Scottoiler themselves this afternoon.
Basically the RMV and Touring kit are still full or relatively full after me doing 2,5k
Spoken to Scottoiler, and have done as they said, and set the RMV to prime, thus causing the oil to pi$$ out
Spoken to a techy guy at Scottoiler (Mark) and he advised me that the oil should be dripping out 1 drop every 40 seconds.
What he also said that just confirmed what Carsick said was that the numbers on the top of the RMV unit are not relative at all to the amount of drops that come out.
Mark told me to run the engine, and set to prime
then slowly turn the nozzle until you acheive the 1 drip per 40 secs, no more than 2 per minute.
Done this lunch time, didn't have enough time, seems to be dripping out, but will try and find the ultimate setting when I get home.
Just note to self for further ref:
The RMV unit on it's own lasts for about 800 miles
The touring Kit last for about 4k - 5k miles depending on useage.
Cheers all, sorry for the long post
Old 28-04-05, 02:40 PM   #2
Ceri JC
Mass, they're right about the numbers not corresponding to "drips per minute" and on mine, if it's set to number 1/2, none come out at all.
It's worth upping the regularity of the drops in wet weather- oil like that in a scottoiler is more likely to wash off than chainwax and similar lubricants.
Also, to see if it's working, as well as leaving the engine running (bike on side stand, in neutral) and looking, just check your back wheel (the actual wheel-not the tyre- shouldn't be any on that ). There's likely to be black flecks on it from chain fling if it's working.
I check mine reasonably regularly, not only to see if it needs refilling, but also to make sure that the level is going down (ie it's dripping).
Old 28-04-05, 03:10 PM   #3
The Mass
Cheers Ceri,
I think I'll have a better go when I get home, I had people banging on the windows in work, when I was checking it earlier because of the noise of the can
Didn't want to upset them too much
I have it set at about 6 - 7 at the moment, so no doubt by the time I get home it'll be all over the place I hope not !
Old 28-04-05, 03:38 PM   #4
Ceri JC
I garage mine at mate's house, so I'm always concious about running the engine on their drive. Last time I was running it in the garage (door up) and the noise, even with my stock can, was immense, the dogs started going mental. Now I check it in the car park at work instead.
Scottoiler Touring Kit on K4 - oh ****! - Very Angry The Mass SV Talk, Tuning & Tweaking 12 12-08-05 11:32 AM
Scottoiler - Touring kit The Mass Bikes - Talk & Issues 2 05-08-05 12:18 PM
Scottoiler - Touring kit The Mass SV Talk, Tuning & Tweaking 2 21-07-05 07:01 AM
Official Undertray/Scottoiler Touring Kit Question Ceri JC SV Talk, Tuning & Tweaking 2 16-05-05 02:46 PM
Fitting a touring scottoiler to a k4/k5 jamesobrady SV Talk, Tuning & Tweaking 4 30-03-05 04:33 PM
