Old 17-05-05, 06:36 PM   #1
jon
Default Running SV without Exhaust / Midsection
Ok, so i've currently got the exhaust and mid section off. I'm very curious as to what it'd be like to start, would this damage anything?
Old 17-05-05, 06:37 PM   #2
Stig
Default Re: Runnung SV without Exhaust / Midsection
YES your eardrums
Old 17-05-05, 06:39 PM   #3
jon
Nothing on the bike? I'll record it
Old 17-05-05, 06:41 PM   #4
jonboy
BigApe does not jest . It is absolutely feckin' loud, so when you do it make sure other people close by (like those within a mile radius with heart problems) know about it.
Shouldn't cause any damage at all but would run rough if you wanted to ride it.
Certainly something you should experience at least once in your life .
Old 17-05-05, 06:45 PM   #5
jon
Crap. Flat battery! I get i better buy a charger tomorrow
Old 17-05-05, 06:46 PM   #6
jon
I lied. ************** that's loud. And sounds retarded.
Old 17-05-05, 07:12 PM   #7
Grinch
I always thought is sounded a bit like a Harley when you take the can off and just run it from the pipe.
Old 17-05-05, 07:31 PM   #8
jon
I got a couple of wav files if anyone is interested (before and after). Unfortunately i wimped out and cut the bike out almost straight away with no mid section and i only had the guts to try it again after i'd taken the laptop in. Still, gives a rough idea for anyone who's not heard it.
Imagine a spitfire on a very slow idle. Without any sort of exhaust.
Old 17-05-05, 07:46 PM   #9
jonboy
Post the links (maybe make them MP3s)?
Old 17-05-05, 07:50 PM   #10
jon
Will do once i've messed around with the files to trim the crap.
Greg, would you know anywhere locally where i can buy brackets for the exhaust? The ones on the current mid section are welded on so i can't use those. The best i found was hose clams in halfords and while they'd do the job they're hardly ideal.
running on 1 farquare SV Talk, Tuning & Tweaking 10 02-04-09 08:08 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Hot Cooper SV Talk, Tuning & Tweaking 12 20-03-07 08:33 PM
Tips for getting the midsection off jon SV Talk, Tuning & Tweaking 15 10-05-05 08:29 PM
running in new sv caines SV Talk, Tuning & Tweaking 9 06-12-04 10:51 PM
