Old 18-06-05, 10:18 AM   #1
fred_dillon
Default Spark Plugs
Hi, after some advise is it best to stick with NGK CR8E as supplied, or does anyone know better?
cheers
Old 18-06-05, 10:33 AM   #2
jonboy
They're as good as anything and if you spend a bizarre amount of dosh on iridium tipped plugs will you honestly know the difference?
Old 18-06-05, 12:01 PM   #3
Clunk
I always used CR8E, never had a problem.
Where abouts in Devon are you Fred ?
Old 18-06-05, 04:36 PM   #4
embee
embee's Avatar
I use the iridium plugs (£15 a pair from http://www.spark-plugs.co.uk/ , is that bizarre )
there are genuine benefits but they are quite subtle. You won't get any more power, but it can help smooth it out just a bit, and especially with carbs it can help hide difficulties in fuelling like "tip-in" after overrun, or cold starting.
If you don't notice small differences then stick to std plugs. If you're picky, use iridium. They last a lot longer then ordinary ones, so you can offset most of the cost eventually.
Old 18-06-05, 08:19 PM   #5
jonboy
Somehow I thought they were fifteen quid each , I suppose for a pair they might be worth trying.
Old 19-06-05, 06:45 PM   #6
I picked up 4 CR8EIXs for £20 a while back on Ebay... I honestly couldn't tell you if they give any benefit other than cold starting, but they're definately better for that.
Iridium spark plugs....yay or nay? sv-robo SV Talk, Tuning & Tweaking 13 03-09-08 11:54 PM
spark plugs daddy_sperm SV Talk, Tuning & Tweaking 12 01-03-06 06:12 AM
cheap spark plugs Warren Bikes - Talk & Issues 10 12-02-06 08:45 PM
Spark Plugs valleyboy SV Talk, Tuning & Tweaking 15 18-05-05 07:51 AM
spark plugs weegaz22 SV Talk, Tuning & Tweaking 4 04-08-03 05:04 PM
