Old 20-06-05, 11:37 AM   #1
Brand New
Default Changing brake pads.
Hi all! The new machine is fantastic, my retinas have taken a beating, but now I have very squeaky brakes, and I feel that there should be MUCH more stop from them compared to what I've got, so, changing of the brake pads it is.
How hard is this? Do I need special tools?
Thanks,
BN
Old 20-06-05, 11:40 AM   #2
Carsick
front ones you just need appropriate sockets and ideally a torque wrench, rear ones you need two different sockets and on pointies one of the allen keys in your toolkit. Needlenose pliars are also handy.
Careful with the back one, I managed to sheer the back bolt while tightening at less than the required torque. I can only assume it was a crap bolt.
To help with the squeaking, put some copper grease where the pad backing meets the pistons.
A question for those in the know, is it necessary to transfer all of the squeal shims from the OEM pads onto new pads?
Old 20-06-05, 11:45 AM   #3
Yokel
Fronts are a doddle but if they're anything like mine you'll need a breakers bar to get the main caliper bolt undone.
Rear is easy enough too, but the little metal clip that holds the pad in place can be an absolute swine to get back on.
Good luck
Old 20-06-05, 11:48 AM   #4
Brand New
Super, I'll give it a whirl. No torque wrench tho...
What pads are most peeps using??
Cheers,
BN
Old 20-06-05, 12:01 PM   #5
Carsick
I just put carbone lorraines on. Nice feel and very good stopping power.
You don't need special pads for the back, just oem ones are easily good enough.
Old 20-06-05, 02:38 PM   #6
richwill68
A question for those in the know, is it necessary to transfer all of the squeal shims from the OEM pads onto new pads?[/quote]
Yup!
Old 20-06-05, 02:39 PM   #7
Carsick
Yup! [/quote]
Including the rears?
I did it anyway, since it seemed like a good idea.
Old 20-06-05, 02:43 PM   #8
richwill68
Yup!
I did it anyway, since it seemed like a good idea.[/quote]
Put 'em back as you take 'em off, mate . Have occasionally just used copperslip without the shims....sometimes it works, sometimes they squeal like buggery!
Old 20-06-05, 02:44 PM   #9
Carsick
I was told that part of the reason for the squeal shims is to absorb some of the vibration that would otherwise go through the piston and knacker it.
Old 20-06-05, 02:45 PM   #10
richwill68
You still here Carsick?
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
changing my pads shakie1973 SV Talk, Tuning & Tweaking 8 25-02-09 12:12 PM
changing pads shakie1973 Bikes - Talk & Issues 0 23-02-09 04:13 PM
Changing pads and caliper cleaning - few q's dyzio SV Talk, Tuning & Tweaking 8 19-08-08 07:39 PM
Changing rear pads Mitch SV Talk, Tuning & Tweaking 8 05-05-07 06:07 PM
