The Sick Man
I am ordering a chain a sprocket set for my bike.
Does the chain chain come closed? Is there any way to remove the pin to split the chain then put it back on without a special tool? What is the best way to do it?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
You can buy an endless chain, or one the comes with a split link. The endless one, you have to remove the swing arm. The split link you will need to purchase/borrow a chain riviter/Tool
Remember to undo the fornt sprocket before you cut the chain. Best way is to use a breaker bar, and a serious block of wood through the rear wheel under the swing arm to stop the wheel rotating. You will need (i think) a 32mm socket for the front nut. Then when the nut is off, get an angle grinder grind off the old chain. You only have to gring the rivets off one of the links, remove link plate, un latch chain. Thats the basics. Personaly i think its just as easy to pay the extra and get it done by somone. You get a warranty and all that. If you want to change your sprockets for tarty ones, then theres nothing stoping you at the time. Just buy them and take them along with you. The bottom line is you need a chain tool, or have to remove the swing arm. |
that chain will not come joined, you'll have to join it... it is possable to join it using a pair of pliers and two hammers (one to hammer and one to hold behind the chain....
I would only use this method if you know what your doing though, either that or buy a chain tool... |
the socket for the front sprocket is a 32...
#5 | |
Ricado, i have a breaker bar and 32mm socket if you need to borrow it
#7 | |
The Sick Man
Viney, that would be most apreciated. Ive got a 16" braker bar, if yours is the same then i only need the socket.
#9 | ||
#10 |
why not pop the bike on the stand (my stand
![]() you're going to have to adjust the tension anyway, so why not go the whole hog & remove it - sounds easier to me |
sprocket and chain Q | ricky | SV Talk, Tuning & Tweaking | 21 | 01-10-09 01:52 AM |
chain + sprocket | SVTristan | SV Talk, Tuning & Tweaking | 2 | 08-05-09 03:01 PM |
Need a new chain and sprocket... Which? | sv_rider1990 | SV Talk, Tuning & Tweaking | 33 | 04-04-08 07:05 PM |
Sprocket/Chain | Mr. Bob | SV Talk, Tuning & Tweaking | 2 | 03-05-07 08:43 PM |
Chain and Sprocket | Ernie B | SV Talk, Tuning & Tweaking | 6 | 04-05-06 12:35 PM |
