Old 19-07-05, 01:13 PM   #1
Banjo
Default GSXR 600 K4 shock onto an SV650S K3
Excuse what is probably a repetative question but how easy is it to fit the GSXR shock?
Is it a straight swap or is a little modification required?
And is it actually worth doing?
Old 19-07-05, 01:18 PM   #2
Flamin_Squirrel
Slight modification is required - the battery box will need cutting back, but not by too much. You'll also need a new nut and bolt for attaching the bottom of the shock to the dogbones.
I thought it was an excellent mod, worthwhile doing. Look into sorting the front out first however, if you've not already done so.
Old 19-07-05, 01:22 PM   #3
Carsick
I think the 600 shock is a little too soft to make it worth it. It's got about the same spring rate as the SV shock, though it has more adjustment and is rebuildable.
I have a feeling it's a different length as well, though can't remember by how much and which direction.
Old 19-07-05, 01:41 PM   #4
Flamin_Squirrel
I think it might be 0.5mm shorter, but I'm not sure.
I'd be surprised if the spring rate is softer, at least by any significant amount anyway, given that it's designed for a similar bike.
A shock with damping that actually works will make up for this anyway.
Old 19-07-05, 01:43 PM   #5
Carsick
It's about the same rate as the SV, though as you say, it has some decent damping. For somebody either my or Banjo's weight, a harder spring rate may be a little more necessary than for you.
Old 19-07-05, 01:44 PM   #6
Scoobs
No it won't!
Old 19-07-05, 04:01 PM   #7
M65
No it won't!
Oh yes it will!
Old 19-07-05, 07:20 PM   #8
Banjo
So do you reckon I would be better going for a GSXR1000 shock instead. One of the reasons for wanting to uprate the shock is due to me carrying a pillion quite a bit.
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
05 gsxr shock dropit987 SV Talk, Tuning & Tweaking 11 22-07-06 10:54 PM
GSXR shock on a K3 lukemillar SV Talk, Tuning & Tweaking 9 05-04-06 09:30 PM
For sale GSXR 750 K5 Shock (SV 650 K3 on shock upgrade) alien19779 For Sale - SV's and SV related items 0 28-03-06 01:16 PM
GSXR Shock The Wolf SV Talk, Tuning & Tweaking 12 23-03-05 12:04 PM
