Bodywork Post your own reviews, opinions and experiences on this subject.
Old 05-08-05, 03:45 PM   #1
Mr P
Default Hamicad tail tidy ......
.... will be fitting tommorrow.
Instructions reckon an hour - anyone validate this or have any other hints to avoid unforeseen pitfalls?
Old 05-08-05, 03:52 PM   #2
Carsick
You can do it in an hour, yes. The only properly fiddly bit is doing the bolts back up once you've got the hamicad back on; the undertray covers them so you have to flex it to get to them.
Old 05-08-05, 05:02 PM   #3
Mr P
Cheers!
Old 06-08-05, 12:28 PM   #4
mines on order!
Old 07-08-05, 05:33 PM   #5
Mr P
Got round to fitting it this morning.
Fairly Straight forward, instructions are pretty good, and no major fitting problems - apart from (right at the end) dropping the seat release cable bolt back into the seat cowl area and having to take it all off again - doh!
I presume most people also change their number plate at the same time? as I had to drill two new holes to refit the stock one, and it (just) fits, so will probably get a slightly smaller one.
What do people do about the rear reflector which I believe is needed for MOT?
Old 16-08-05, 06:25 PM   #6
M.C.
M.C.'s Avatar
this is where i put mine used the std reflector, i made a metal bracket and bent it around so that it sits on top of the number plate light then i drilled a hole in the top of the light and secuered it with a m3 screw and nylock nut
M.C. is offline   Reply With Quote
Old 17-08-05, 12:10 PM   #7
Lee Rainbow
the hardest thing i found was taking out the little black popper fittings which hold it together
Hamicad Tail Tidy Fleagle For Sale - SV's and SV related items 6 03-05-07 07:44 PM
Hamicad Tail Tidy amuli For Sale - SV's and SV related items 7 29-03-07 12:47 PM
Hamicad Tail Tidy a1a SV Talk, Tuning & Tweaking 3 25-12-05 02:40 PM
Do I need to fit Hugger if I have tail tidy (Hamicad)? jump SV Talk, Tuning & Tweaking 13 22-04-05 05:34 PM
Just received my Hamicad tail tidy... jump SV Talk, Tuning & Tweaking 7 20-04-05 10:26 PM
