Old 18-08-05, 07:28 AM   #1
mysteryjimbo
Default My Dynojet experience
I thought I'd give the story of my fitting a dynojet kit to my Gixxer 6 to let you know how difficult it was to fit and whether there were any benefits.
My GSXR 600 SRAD suffered from a very lean 4.5-5.5k on the rev range (as they all do) which was made worse by having an aftermarket can on. This coincidentally, happens to be the revs I hit when I’m filtering in 2nd gear. So the decision was made to purchase a kit. As luck would have it I got a complete one for £25 off eBay!
Even though the kit came with instructions I decided to use my initiative and go about downloading the latest instructions from the Dynojet website for the kit. All checked out, the leaflet number was the same and all of the parts listed were the same. I did notice some differences though. The older leaflet said to leave the original pilot jets fitted and that the ones supplied were for race use only. This wasn’t even mentioned on the newer copy even though the part numbers were identical.
In my wisdom , I decided to go with the newer instructions as they must have been updated for better usability. I went about fitting the kit on Saturday. The initial result were “ok” at best. But I thought, hey, maybe they require a little tweaking to get them just right. Which is what I did over the past few days. I messed with the mixture a little more trying to get the perfect setting. Every now and then I thought it was an improvement but when I tweaked it a little more it was gone again.
So yesterday the decision was made to go with the original instructions to see if there was an improvement. So last night I was sat at the kitchen table again with my carbs sat in front of me with a screw driver following the old instructions. I fitted the back on and “hey presto” everything started and it all sounded great. I took it for a test ride to see how it felt and it was great. Tons better than the original setup. Admittedly it isn’t perfect as I don’t have the dyno or the skills to get it bang on, but it felt good.
So my initial impressions. That 4.5-5.5k lean spot has gone completely and it feels lovely and smooth right though the rev range. It still has it peaky roar at around 10k and the power jump there is still as mental as it always was. The power just feels a much smoother curve now with no sudden peaks.
So in reflection, dynojets are a great improvement BUT always follow the instructions supplied….
dynojet kit? bungfruit SV Talk, Tuning & Tweaking 10 13-08-08 04:35 PM
Dynojet Kit question zz-rrrr SV Talk, Tuning & Tweaking 5 27-05-07 09:23 PM
dynojet - easy to fit? 01 sv650s SV Talk, Tuning & Tweaking 21 20-10-06 08:23 PM
Dynojet Kit stev SV Ecosse 10 12-04-06 08:25 PM
Dynojet Kit gman SV Talk, Tuning & Tweaking 7 15-05-05 01:35 PM
