Old 09-04-06, 08:03 AM   #1
stev
Default Dynojet Kit
Anyone fitted one of these to a sv650 or got any experience of them ?
Am told it's a good idea if you fit a k and n filter and free flowing exhaust but can't find info on them, just prices and where to buy them.
stev
Old 09-04-06, 07:19 PM   #2
GDBD59
Click on the search button on the top, & select "tuning & tweaking forum" & type in Dynojet. I think you'll get one or two threads
Apart from that, Northwind'll be able to give you chapter & verse when he drops by
Old 10-04-06, 03:22 PM   #3
Nah, can't be bothered
Old 10-04-06, 03:42 PM   #4
Oh well, maybe. Basically, yep, good idea if you want to fit a K&N. But I'd say don't bother doing either though- even set up perfectly (which means a trip to the dyno man at YPE, most likely) you're going to get a fairly small benefit from the K&N and kit. Certainly not £100 worth of benefit IMO, which is probably the minimum it'd cost you, for the filter, kit and dyno time. Even then, you can get 9/10 of the benefit with a couple of quid's worth of main jets, and otherwise using stock parts.
If you had a full system, and a desnorkelled filter or a BMC race RS, or K&N pods, then rejetting's essential and worthwhile though.
Old 11-04-06, 08:12 PM   #5
stev
so if I get you right, you say -
"just go up a main jet size, and shut up ?" and that's to make sure it's not running too lean ......
Stev
Old 11-04-06, 09:22 PM   #6
Well, depends on exactly what you do. If it's a K&N and slipon, then yep, up a jet size, maybe up a notch or half a notch on the needles. If it's a slipon, it ought to be fine as stock really.
One of the nicest, easiest tests for the health of your engine is to cruise in 3rd or 4rth gear at 5000 revs, then crack the throttle open fast. If it hesitates before it takes off, you're probably needing bigger jets. It's hardly fullproof but it's the closest thing to a litmus test I can think of. Or give it to me to commute on for a month
Ultimately, I reckon the smart thing to do no matter what you do is to pop it on a dyno afterwards, it's pretty cool anywya, not expensive, and gives you a bit of peace of mind. Mine's well overdue for it but every time it goes near a dyno a bit falls off
Old 11-04-06, 10:51 PM   #7
GDBD59
Usually the rider
Sorry Andy, couldn't resist.
Old 11-04-06, 11:01 PM   #8
I suppose I can't blame you, it was a perfect opportunity
Old 11-04-06, 11:15 PM   #9
SVTONYB
Usually the rider
Old 12-04-06, 07:40 PM   #10
stev
Northwind
thanks for the advice. I appreciate it as I'm loving this sv and want to get the best from it, without it breaking down on me. Like the sound of a 700cc kit though
where could i buy jets from ? the local dealer went into liquidation last week(alvins)
Stev
dynojet kit? bungfruit SV Talk, Tuning & Tweaking 10 13-08-08 04:35 PM
Dynojet Kit question zz-rrrr SV Talk, Tuning & Tweaking 5 27-05-07 09:23 PM
dynojet - easy to fit? 01 sv650s SV Talk, Tuning & Tweaking 21 20-10-06 08:23 PM
Dynojet kit for Curvy Ter Stuff Wanted 0 30-05-06 10:30 AM
Dynojet Kit gman SV Talk, Tuning & Tweaking 7 15-05-05 01:35 PM
