is it possible, has anyone done this? is there much difference in height at the tail? soz havent looked at a k3 closeup.
ta |
there is for sure a difference but i am unsure as to what.
hth ![]() ![]() ![]() |
Is this for a particular reason or do you just happen to have a K3 sub frame to hand?
no particular reason, mainly looks. i am 6ft 4 so i kinda dwarf it and yes i know of a cheap one. just thinking of an alternative to dogbones
Yeah, the K3 subframe is vastly superior to the K4/5 one
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
The man has a good point. Would the K4 plastics go on the K3 subframe, though? If this would actually produce a bit more distance from seat to pegs, I would consider it.
You may need a K4 seat to go with the subframe. Not sure they are easily interchangeable.
The Sick Man
What about the exhaust hanger or link pipe. This will be diffrent too.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#9 |
Exhaust hanger is the same across the pointy range. The seat, and rear plastics are not. You would need those as well - they have clearly different part numbers in the microfiches.
The battery box is also different.
#10 |
The hanger is the same, but I'm pretty sure the system isn't.
Subframe | viffer | Mini-Twins | 7 | 14-11-08 11:36 PM |
03 Sv subframe | charris | SV Talk, Tuning & Tweaking | 0 | 13-07-08 06:42 PM |
Subframe material. | Sideshow#36 | SV Talk, Tuning & Tweaking | 7 | 11-06-08 04:25 PM |
Bent Subframe | Torn-Thorax | SV Talk, Tuning & Tweaking | 6 | 05-03-07 06:53 AM |
subframe swap | gc350 | SV Talk, Tuning & Tweaking | 0 | 04-02-07 03:56 PM |
