Old 16-11-05, 09:05 PM   #1
PLAYAROUND
Default Lights not working?
On the way home from Box Hill tonight the front lights went out and all four indicators went on and on the dash the two indicators went on with the full beam light.
Any idears about why this happened?
MATTP
Old 16-11-05, 10:25 PM   #2
svrash
Default Re: Lights not working?
MATTP
Fuse :P
Old 17-11-05, 09:42 AM   #3
PLAYAROUND
Default .
The bulbs are all fine and the fuse box is all good.
I was thinking it could be a warning sign for a service or something like that?
Cheers for any and all help
Old 17-11-05, 09:52 AM   #4
fizzwheel
fizzwheel's Avatar
Not sure if it might be this, but its worth a look
Follow the wiring loom back from the headstock where it disappears into the bike and have a look and see if you have a wire thats rubbed through it insulation and it rubbing on the frame and causing a short or something like that
Curvey SV's are known for this and it might cause problems like you are getting
HTH
Key not working wilky007 SV Talk, Tuning & Tweaking 12 29-12-08 01:27 PM
Display lights not working joff80 SV Talk, Tuning & Tweaking 3 27-09-08 01:32 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
Which head lights should be working in dipped operation? Dirk Eisner SV Talk, Tuning & Tweaking 5 23-10-06 02:26 AM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
