Old 27-11-05, 05:30 PM   #1
ben650
Default help removing wheels?????
im having the rims polished on my k5 nakid to complement the spray job,but im new to the orld of bikes so i have a couple of question's sorry
i have a paddock stand so the backs sorted,but how do i go about getting the front end up in the air?
Is there any thing i need to know before i get to work?,or is quite straight forward?
Cheers for any help guys ill get some pics up when she's back together
Old 27-11-05, 06:01 PM   #2
Scoobs
Jack it up from under the engine block. Put a piece of wood between the jack and the block to prevent damage.
Old 27-11-05, 06:08 PM   #3
Biker Biggles
Biker Biggles's Avatar
Loosen all the bolts first as it won't be very stable on a rear stand and jack.Some additional support would be good if you can rig it up.
Old 27-11-05, 06:10 PM   #4
ben650
cheers guys isn't the exhaust in the way if i use a jack?
Old 27-11-05, 06:16 PM   #5
Biker Biggles
No.Jack it from the near side under the sump with a block of wood to spread the load.
Old 27-11-05, 07:18 PM   #6
Cloggsy
You could just get a front stand
Old 27-11-05, 07:30 PM   #7
ben650
guessing thats you? they any good?
Old 27-11-05, 07:52 PM   #8
Abba or NWS stand's better, and not much more than a front and rear stand... You've got to be fairly brave to take the front wheel off on a typical rear stand. Because the engine base is fairly far back, if you jack it under there you're too close to the centre of gravity for stability. If the rear wheel's off it's even less fun.
Old 27-11-05, 11:18 PM   #9
Joe110
You also need a 17mm allen key on a socket to remove the front wheel.
Old 27-11-05, 11:29 PM   #10
Mike1234
According to the workshop manual (and the hex drive I have in the draw) it's a 12mm one you need.
Removing all plastics DarrenSV650S SV Talk, Tuning & Tweaking 3 03-12-07 08:08 PM
Removing clocks sisk650k4 Pennine Massive 4 19-09-07 04:18 PM
4 wheels good, 2 wheels better Dysparunia Bikes - Talk & Issues 6 30-11-06 07:37 AM
removing handlebars EM SV Talk, Tuning & Tweaking 2 02-03-06 05:58 PM
Removing a baffle from ccc can Kirmit Exhausts 7 09-02-06 10:43 AM
