Old 20-01-06, 11:14 AM   #1
triumph5ta
Default Radiator mount query and parts list
My 99 nekkid curvy has a radiator that I cannot fasten properly. It has two bolts at the top which are fine. Then there is a fitting at the bottom right hand side of the rad to enable it to attach to the top of the front cylinder. The front cylinder has a casting which has no hole to pass the bolt through. Wots going on? Have I missed something? The rad has brackets either side with rubber grommets in it which look like they should attach to a fairing. This suggests to me that I have a rad for an S model... Ideas?
Does anyone sell a parts list for the SV? I mean the real Suzuki thing or copy of it...
Adam.
Old 20-01-06, 11:44 AM   #2
You've got a rad for an 'S' and there is a rear cam cover on your front cylinder.
What's the betting there's a front cam cover on your rear cylinder?
Or maybe the rad was replaced as the bike's been crashed and the cam cover was damaged too, and has been replaced with a rear cover.
Or maybe...
I'll stop now.
I need a list of parts? martin.sv750 SV Talk, Tuning & Tweaking 4 29-09-08 06:54 AM
add me to the list.... WestleyTDPR Idle Banter 16 23-06-08 02:50 PM
Parts list webpage Wally SV Talk, Tuning & Tweaking 7 10-07-07 01:22 PM
Online parts list chazzyb SV Talk, Tuning & Tweaking 3 17-03-07 09:44 PM
Chassis Parts Query Ceri JC SV Talk, Tuning & Tweaking 2 17-05-05 09:45 AM
