Old 23-01-06, 06:26 PM   #1
Freeloader
Default Another strange question...bike won't reverse
Sorry about the recent level of stupid questions. Im just not very clued up on SV problems yet...
...tried to reverse the bike out the drive this morning (walk it backwards) and the bugger was SOOOOOOOOO hard to move it wasnt true. It wasnt in gear. What can this be and is it common? The bike seems to ride just fine and even when i got off it to push i had a hard time.
Joe
Old 23-01-06, 06:41 PM   #2
Ed
Have you checked your tyre pressures?
Are you positioning yourself correctly as against the bike?
Brakes binding a bit?
Driveway uphill?
The bike is heavier than you'd think. Suggest get a mate to have a go at pushing it, see what s/he thinks.
Old 23-01-06, 06:45 PM   #3
jonboy
There's often a bit of clutch drag when it's in neutral which makes it difficult, possibly (as Ed suggests) your pads might be binding very slightly too.
This is pretty common.
Old 23-01-06, 07:20 PM   #4
TC3
Might be a good time to join a gym.....
Old 23-01-06, 07:49 PM   #5
madderdog
my brakes bind something terrible makes it a bu@@er to move. Find it easier going backwards as you can use body weight.
Old 23-01-06, 07:52 PM   #6
Biker Biggles
Biker Biggles's Avatar
I vote for brakes binding.Check em and cleann the pistons.
Also,as the pads wear down they can become a bit uneven such that they bind a bit but only when reversing.
Old 23-01-06, 08:00 PM   #7
chazzyb
Ditto brakes binding. Mine have been too with my usage patterns - weekend rides only, hose down and put away. Next weekend, one of the front calipers is binding, so long term clearly needs stripping and fettling. A pre-ride session alternating with application of the rubber mallet and applying the front brake sorts it out (until the next week).
Not a lowering question, quite the reverse - how to get more room? clanger SV Talk, Tuning & Tweaking 20 12-03-10 02:27 PM
Strange paint question... sam_p2000 Idle Banter 8 26-02-09 04:18 PM
Linux/Internet Speed Question...Strange! poisonidea Idle Banter 3 21-08-08 05:47 PM
Strange noise from bike ricky Bikes - Talk & Issues 6 22-05-08 10:09 PM
Strange question but....... nickj Idle Banter 5 20-08-06 09:49 PM
