Old 08-02-06, 12:55 PM   #1
rob13
Default Replacing engine coolant
Is there any easier way than to remove the whole front cowling to replace the coolant? It makes a simple job much more complicated.
Old 08-02-06, 12:55 PM   #2
BillyC
BillyC's Avatar
There is a drain bolt on the side of the water pump, on the right hand side of your engine.
Old 08-02-06, 12:59 PM   #3
rob13
but to fill it up, i need to remove the cowling?
Old 08-02-06, 01:11 PM   #4
BillyC
BillyC's Avatar
Ah, yeah you might - but that's not what you asked
Old 08-02-06, 01:12 PM   #5
BillyC
BillyC's Avatar
Oh I suppose you did... be thankful that you only have to do it once every 2 years.
Old 08-02-06, 01:36 PM   #6
You only have to take the right side panel of the fairing off.
Old 08-02-06, 01:50 PM   #7
cosmiccharlie
Default coolant change
I'm due for mine to be changed and was looking here and noticed the right side fairing is to be taken off, is that to get at the pressure cap and is it necessary to remove the pressure cap to refill the coolant,
I know it sounds lazy but my local shop suggested £40 all in for a brake and coolant change but am tempted to try these myself
Sorry for being a numpty but slowly getting the hang of this spannering business,
Old 08-02-06, 02:08 PM   #8
Default Re: coolant change
Originally Posted by cosmiccharlie
I'm due for mine to be changed and was looking here and noticed the right side fairing is to be taken off, is that to get at the pressure cap and is it necessary to remove the pressure cap to refill the coolant?
Yes, and yes.
That's a good price, does that include fluids? As long as you're happy to work on your own brakes they're both easy jobs.
Sorry for being a numpty but slowly getting the hang of this spannering business.
Join the club.
Old 08-02-06, 02:18 PM   #9
cosmiccharlie
Yes the £40 Quid is inclusive of everything,
i'm happy at trying got a little bleeder kit and all the bits just being first time kind of reluctant - hope you understand
and the coolant doesnt seem that tough, just need a big hose for flushing it all out and draining,
Old 08-02-06, 04:55 PM   #10
If I could get my brake fluid and coolant done for £40 all in, I'd take it, even though doign the work myself is no problem. Excellent deal.
Changing engine coolant touch107fm Bikes - Talk & Issues 1 25-06-08 02:46 PM
Changing Engine coolant - remove fairing? stone SV Talk, Tuning & Tweaking 1 30-06-07 02:59 PM
Speedo Rotor & Engine coolant leak Nitzer SV Talk, Tuning & Tweaking 2 02-01-07 09:20 PM
engine coolant fullstop102 SV Talk, Tuning & Tweaking 10 31-07-06 09:44 PM
Engine Coolant. creamerybutter SV Talk, Tuning & Tweaking 30 13-01-06 10:34 AM
