Old 20-02-06, 04:47 PM   #1
russg
Default am stupid (brakes)
em i have a problem i think
i took my front calipers off my curvy bike so i could clean my front forks cause the salt was getting to them any
i was taking to my mate and with out realising i pulled the front brake as soon as i done it knew there could be a prob
do i just try and prise them open again or what they are not completly closed still enough to get a flat screwdriver in to i think
any help would be great
thanks
________
FORD T PLATFORM
Old 20-02-06, 04:59 PM   #2
Bez
Yes you need to get something in there to lever the pistons back in. It would be wise to remove the pads as they could crack it you lever on them with a bar of some sort. With the pads removed use a piece of wood across the back of the caliper and bar against that.
I think some people use a G-clamp to do this.
Good luck
Old 20-02-06, 05:30 PM   #3
The above is good advice, and if there's any resistance to pushing the pistons back you'd be well advised to take it. However, if you use a wide bladed lever/screwdriver you should be able to push the pads apart without any further dismantling, as long as you're careful not to damage the pads it'll be fine.
Old 20-02-06, 05:31 PM   #4
Last Action Pimp
take the pads out and clean the pistons, i use a thease
just be careful
Old 20-02-06, 05:36 PM   #5
Iansv
yep just be careful, i've done it before
Old 20-02-06, 06:04 PM   #6
jambo
jambo's Avatar
When using a flat bladed screwdriver to push the pads and pistons back don't go too far as you'll start forcing dirt and rubbish back past the dust seals in the caliper.
Old 20-02-06, 08:05 PM   #7
didge
lol yer i did the same thing yesterday but it was the back caliper, any way is used a screwdriver to prise it open with the pads in but still got it in so it was ok
Old 20-02-06, 08:44 PM   #8
valleyboy
DO NOT use the discs as something to lever against.... I did that on my kwak, and I suspect thats what caused one of the discs to warp... and fork out £200 to replace ONE disc
Old 21-02-06, 10:26 AM   #9
russg
thanks for the info guys i gonna do it tomorrow am dreading it already
never mind am sure i will get there thanks guys i will let u know how i got on
________
GANG BANG PORN
Old 21-02-06, 03:28 PM   #10
just be careful
What the hell for?
Stupid stupid stupid snow and ice!!! Giggsy Idle Banter 6 14-12-08 03:38 PM
Stupid? plowsie Idle Banter 6 24-05-07 10:41 AM
Stupid is as stupid does... Demonz Idle Banter 8 18-04-07 02:36 PM
Stupid Jabba Idle Banter 6 02-09-06 06:06 AM
There is stupid and then there is REALLY stupid Stig Bikes - Talk & Issues 15 01-12-05 11:36 PM
