I'm 99% certain my RR overcharges, but only when its hot, which has made the diagnostics chalenging
![]() RR checks out OK as per the Electrex check sheet Battery checked out OK by Halfords on their digital thingy Charge rate still climbs if I leave the engine idling for long enough (shows 12v with lights on but 15.9v with them off) I've 'ad enuff! It's going to get a Ho*da/Kwak RR and like it In one of your many (& excelent) posts you refer to the tied back 2 pin connector near the RR. Can one of these terminals be used for the reference voltage, or do I need to go somewhere like the brake light switch supply lead Cheers Tris |
Hallelujah!
The firstest ever SV that overcharges, yippeee!!! Back to the point: The two pin connector I have referred to in that area has a loopback on it and is used for a starter lockout that, (I think), Brit/Euro bikes don't have, you can make use of it when fitting an alarm/immobiliser, well... if that's the one we're both, (possibly), thinking of. You can connect the 'extra' wire on a six wire reg/rec to the live feed to the rear brake light switch.
Cheers Mate
Tris |
A prize! | Neeja | Idle Banter | 22 | 11-07-08 11:05 PM |
Prize For The 1 Millionth Post | blueto | Idle Banter | 7 | 10-05-08 12:52 AM |
So do I win a prize... | philbut | Thames Valley | 23 | 30-04-08 09:03 PM |
Guess My Premium, Prize To Be Won | squirrel_hunter | Idle Banter | 46 | 24-08-07 08:33 AM |
do i get a prize? | kwak zzr | Idle Banter | 4 | 19-10-06 02:30 PM |
