Old 26-03-06, 02:06 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default You couldn't help with the brakes BUT how about the chain??
I am going to buy a new chain, I NEED one. but I want to do it. Can't learn unless you have a go eh.
Question is
A: Any advice as to which chain and how much?
B: Anyone can help/assist/overview/babysit* me. I know you need some special tools so I'm hoping one of you lurvley people can help?
C: Do I need or should I get a new sprocket while I'm at it?
Stretchie (Thundercat NOT SV)
* delete as appropriate[/u][/b][/u]
How to amuze an idiot:
Look right-> <-Look Left
Old 26-03-06, 02:13 PM   #2
valleyboy
Right, I just bought a new chain/sprocket set...
I bought it from hein Gericke, it cost £101 all in.... thats for 2 sprockets and a chain.... prices will probably differ rear sprockets easy to change, take rear wheel off, undo bolts, plonk on new one... front sprocket needs a bit more work. Im having the garage do mine now, as I almost tipped the bike over trying to wrench the bugger off! You will probably also need a new washer for the front sprocket as well, you put it on, tighten the nut, and bend it over the nut then so it cant undo itself.
As for chains, you will need to split the old one and get that off... or if you want, dremmel the critter off!
new chain, you will have a rivet link... this is where that tool is needed.. and they aint cheap.... again, garage is doing mine, as I wont trust myself with that!
With above questions, replace sprockets and chain at the same time..
I wont mind giving a hand, but i will be learning at the same time.. and also have people to phone for advice if it goes FUBAR!
Do you have a rear paddock stand ? as you will need to take the rear wheel off...
Ohh, you may want to do some reasearch into what sprockets etc you want.. as original ones are rather expensive.... Renthal are what ive ended up with... and have a look at the toothing.. make sure you have the right sprockets and chain length
Old 26-03-06, 10:01 PM   #3
tinpants
Ubique
tinpants's Avatar
Busters were doing a suitable c+s set for around 90 quid plus postage. Give 'em a bell and see if they can help.
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
Old 27-03-06, 07:52 AM   #4
anna
anna's Avatar
and you still want to do this????
Old 27-03-06, 02:40 PM   #5
Haxsaw
From what I know, it's a false economy to replace chain & sprockets separately: one will just destroy the other.
As for fitting them yourself, I would be inclined to get it done professionally, especially if you've an endless chain, which is likely.
Old 27-03-06, 03:03 PM   #6
Grinch
Just got mine from here...
Trade Direct
90 quid plus postage... Xring chain...
Or there is
B & C Express
starts at 95 quid for x-ring chain
Old 27-03-06, 03:34 PM   #7
anna
anna's Avatar
If I'm around I'll happily overview you doing this.. perhaps make the tea! ...
Havent done an SV one to know but would happily lend a hand if one hand is any good.. other one will be drinking tea
Old 27-03-06, 04:16 PM   #8
Anonymous
If you guys want a garage, come over to mine and I'll help........by making the tea
Old 27-03-06, 04:28 PM   #9
valleyboy
looks like a gathering of the mechanicaly challenged then!!
Torque wrench anyone??
hmm, my bike should have an endless chain, but like hell am I taking the swingarm off to do all that work... as is, the one supplied wasnt endless, and its being fitted on Thursday.. which means a treck over the mountains for me in what can be said as shait weather! which happens to be windy as hell on a good day
Now I must go and put my Iridium spark plugs in the bike...
Old 27-03-06, 04:42 PM   #10
Anonymous
Aha...got you there, I have one (a 6-80)
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
brakes ralph SV Talk, Tuning & Tweaking 2 20-03-06 08:22 PM
No Brakes The Mass SV Talk, Tuning & Tweaking 13 16-11-05 11:01 AM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
