Old 30-03-06, 11:13 PM   #1
BIKER-DENE
Default gear lever adjusting?
i cant get my foot under my gear changer propperly.. can you adjust it so ist higher?
thanks
dene
Old 31-03-06, 07:23 AM   #2
Yes, undo the nut either end of the rod between the lever and the gearbox, note one nut is a reverse thread, look at threads first it should be obvious which way each must be turned to slacken it. Rotate the rod and the pedal will rise and fall, when you're happy with the position of the pedal, nip up the nuts.
If the lever is a long long way too high or too low, then you may need to remove the front fitting and rotate it on the gear change shaft that passes in to the gearbox, this is unusual however, so try the above first.
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Gear lever as rear brake lever? plowsie SV Talk, Tuning & Tweaking 2 29-05-07 05:23 PM
