Old 13-04-06, 01:09 PM   #1
sprocket
Default Pilot Bolt
The fuel air mixture bolt on my front carb has completely seized. The last time I tunred it it had been set to 2 1/2 turns and now its completely seized up and I need to have a play with it. I've tried heating it and I've soaked the area in carb cleaner.
What I was wondering is, is it possible to order a new bolt and just drill the current one out?
Thanks
Old 13-04-06, 07:48 PM   #2
21QUEST
21QUEST's Avatar
Yep. order the spring , O Ring and washer as well as thet will more than likely be damaged .
Careful with the drilling eh .
Ben
Nemo me impune lacessit.
Old 13-04-06, 10:33 PM   #3
svrash
Default Re: Pilot Bolt
Thanks
I got a spare set of carbs you can rob the bit you need from mate
Pilot power vs pilot road James SV Tyres 30 18-05-09 10:20 PM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
Help me build a spare bolt box; what are all the common bolt F16Falcon SV Talk, Tuning & Tweaking 10 07-05-07 08:42 AM
Pilot Power or Pilot Road? mario Tyres 3 06-10-06 03:45 AM
Michelin Pilot Sport or Pilot Power ? mihaip Tyres 0 22-09-06 12:02 PM
