Old 14-04-06, 09:08 AM   #1
wtdafk
Default Brake Pads?
how long do they usally last? mine have done 4000miles but they feel a bit scrapy if u know what i mean they kinda hiss a lil bit but they arnt grabby, when i look at them when still on the bike in the caliper you can still see the groves and they look like they got quite a lot of meat left. should i take them apart just to check or will they be ok?
when i got the hissing sound on my last bike it ment the pads were worn right down but they still look fine at da mo maybe they could just need a clean?
cheers, have a gd easter
Old 14-04-06, 09:15 AM   #2
Stig
Take the pads out and give them a scrub. Also clean your discs. Clean out each and every hole in the disc and clean the surfaces using a brake and disc cleaner.
You should fine a marked improvement.
Old 14-04-06, 09:16 AM   #3
Stig
Oh and make sure that the pads go back in the same position. Left pads into the left calliper etc...
Old 14-04-06, 09:29 AM   #4
wtdafk
cheers ive only ever changed the front pad on my old nsr125 before (back one was to tight) i imagen it will be pretty much the same on my sv? just a case of taking it off then opening it up then opening the pistons wiv a screw driver or summin to get the pads back in?
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Brake Pads trevrobwhite Hardware 10 18-04-08 01:21 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
what brake pads ianofbhills SV Talk, Tuning & Tweaking 2 02-03-06 08:55 AM
Best Brake Pads Dan_SV SV Talk, Tuning & Tweaking 8 01-03-05 02:08 PM
