Old 14-04-06, 02:57 PM   #1
lockery
Default Anyone know what the green box electrical part is called?
OK, I have established that on my 1999 SV650S there is a fuse which has melted into nothing in a green semi-clear fuse box with 2 large cables screwed onto the part which I presume is from the battery. It sits on the right hand side of the bike between the battery area and the fuel tank. It has 2 fuses inside and a load of wires coming from the top which are plugged in to the part. 2 large wires in the front.
I have a 30 amp fuse which has melted and the part still has much of it in there and so I need to replace it.
Any ideas what this thing is called or where to look it up on a diagram?
Thanks for the help... assuming anyone will or can.
Old 14-04-06, 03:05 PM   #2
Starter solenoid, sometimes referred to as starter relay, also contains one fuse - the main fuse, the other is a spare 30A.
Old 14-04-06, 03:05 PM   #3
454697819
i believe it is the starter relay fuse holder thingy magigy...
hope that helps
Old 14-04-06, 03:15 PM   #4
lockery
Default cool, cheers
Thanks for that. I just looked up a manual and downloaded it. It said the same thing. Does any one know if its easy to change by someone who is not good at this kind of thing... also, is it an expensive item?
Old 14-04-06, 03:24 PM   #5
Don't know about price, but it's easy to change:
Disconnect battery, remove battery and starter wires from solenoid - noting what went where, remove multi-plug, wiggle solenoid off it's rubber mounts, wiggle new one into place, replace wires and plug, reconnect battery.
Don't forget to make sure the green placcy cover has the two heavy cables running through the hole in it.
Old 14-04-06, 03:28 PM   #6
lockery
Cool, does the part need to be for an SV or can it come from another suzuki. I remember reading about someone who used a GSXR regulator rectifier rather than an SV and it was about a 3rd of the cost of my SV part.
Does that work with these items too do you think... Im just starting to get into the concept that a bikes parts can be touched without it all blowing up!
Old 14-04-06, 03:42 PM   #7
rictus01
rictus01's Avatar
Got a spare here if your interested?
Cheers Mark.
Old 14-04-06, 03:53 PM   #8
lockery
Hi Mark, is it new or old, SV 1999 or something else? What are you asking for it?
David
Old 14-04-06, 04:25 PM   #9
rictus01
rictus01's Avatar
David
It's of a k1 so will fit (although unless I'm mistaken only the rubber mount is different on the later ones anyway)
£10 to you sir, I see your only in Shoreditch as I'm going up to Covent garden this evening I could perhap drop it off?
Let Me know in the next hour or so.
Cheers Mark.
Old 14-04-06, 04:29 PM   #10
lockery
Just sent you an email with my number on it Mark. Tonight would be good.
David
What's this electrical part? twonky SV Talk, Tuning & Tweaking 15 10-02-09 01:09 AM
What's it called? (Pointy part enquiry) Baph SV Talk, Tuning & Tweaking 2 05-12-08 09:18 PM
Whats this part called? stephencassidy SV Talk, Tuning & Tweaking 4 29-04-07 02:57 PM
HM Racing in green street green hall13uk SELKENT 4 16-06-05 04:25 PM
The Rose and Crown Green Street Green Orpington Kent sexysi The Good The Bad and The Ugly Pub and Cafe guide 4 17-06-04 09:14 AM
