Old 26-04-06, 11:21 PM   #1
Joe110
Default If you give an SV a real hard time whats the 1st thing to
If you give an SV a real hard time whats the 1st thing to break in the engine?
Old 26-04-06, 11:32 PM   #2
Nexus242
"Give an SV a real hard time"??
What do you mean?? Like being mean and nasty to it and calling it names or what??
Old 27-04-06, 12:13 AM   #3
It depends on what sort of hard time, like the man says... The SV's solid but it's no GSXR1100, if you abuse it in the right ways it'll die. It's spun bottom end bearings mainly. Though you can snap the crank if you put the effort in, and a few have snapped a rod, or you can tear up the top end if you know how
Old 27-04-06, 12:33 AM   #4
Joe110
I've started doing trackdays and it gets abused a heck of alot more than on the road, I woundered if they would stick it. Things like going down the gears real hard and the bike almost red lining through changing down to fast, slipping the clutch in tall gears and other genral abuse, I know everybike will wear out if you ride them hard, but I was just checking to make sure the SV is tuff, as I come from a MX back ground.
Cheers Joe.
Old 27-04-06, 12:45 AM   #5
rictus01
rictus01's Avatar
Ah my specialist subject
first and primary cause (and this should get some comments)
give it to a certain tunning company
but after that, well if it's cause by oil starvation then the big end are vunrable as is the rear cylinder small end (runs slightly hotter).
if not then the cam chain tensioners can brake, dropping bits into the bottom, or stick resulting in the cam chain "whipping" to braking point (but the noise beforehand should tell you something is up).
very early models lacked a baffle plate in the engine so wheelies could cause oil starvation ( see above but effecting the front cylinder).
I've seen other things fail on various SV lumps but these are the only ones I've seen more than once.
Cheers Mark.
whats the best thing about the sv650 jans1971 Bikes - Talk & Issues 50 08-07-08 03:45 PM
whats the worst thing about the sv650 jans1971 Bikes - Talk & Issues 80 28-10-07 11:24 AM
whats the best thing to get next jans1971 Bikes - Talk & Issues 11 17-10-07 11:58 AM
Whats that pointy bar thing... furrybean SV Talk, Tuning & Tweaking 16 27-03-06 05:11 PM
Will I ever stop dropping it or is it time to give up? Lanaby SV Talk, Tuning & Tweaking 24 17-02-05 10:30 PM
