Old 29-05-06, 10:37 AM   #1
mastiffmat
Default Cleaning 'soft' plastics
Anyone have a good way to clean up 'soft' plastics that have been scratched. For instance, the tail lights on my pointy SV have got a bit scratched up and I'd like to polish them up a bit.
All ideas gratefully received!
Mat
Old 29-05-06, 10:47 AM   #2
ben650
g3 compund is good for this,put a bit on a soft cloth,dip it in water and rub away
Old 29-05-06, 11:40 AM   #3
mastiffmat
Thanks - had a look around for G3 but it seems to be sold as a paint rub-down compound rather than plastics. Would it be too course for plastics?
Old 29-05-06, 01:48 PM   #4
i use it on the car and it works fine dunno about bikes tho? i wouldnt want to put anything on the bike bodywork which may make it look worse. try it on a spot you cant see first.
Old 29-05-06, 04:53 PM   #5
embee
embee's Avatar
Various plastic polishes here
http://www.lasaero.com/las/900?cat=11
I haven't had anything from them, mind.
I understand the Plexus polish is supposed to be good, also available from
http://www.nippynormans.com/products.asp?dept=278
Old 29-05-06, 06:34 PM   #6
Arm & Hammer toothpaste, the sort with baking soda. It's an incredibly fine abrasive... Often recommended, but I've never tried it myself.
Old 29-05-06, 08:20 PM   #7
Xan173
Hi, does anyone know if orginal Suzuki body plastics are made from coloured bead (ie. does the colour go right through) or are they painted?
Old 29-05-06, 08:52 PM   #8
Painted.
Old 29-05-06, 11:06 PM   #9
Speedy
This sounds awful,but I have used T-Cut on some plastics that were scratched!
Not on my bike I must add,but if you're gentle tis good!
Old 29-05-06, 11:30 PM   #10
454697819
tcut is good but i wouldnt use it on any paint work that is les than 3 yrs old, unless its lived in the sun
i use t cut and then either merr or pledge, lemon fredh is best caus eit makes your bike smell clean too
I'm turning soft mister c Idle Banter 8 01-12-08 09:49 PM
Am I getting soft timwilky Pennine Massive 16 18-11-07 01:50 PM
What is it about soft top MG TF drivers Tris Idle Banter 12 10-05-07 03:47 PM
soft panniers Tomcat Stuff Wanted 0 11-01-07 03:20 PM
Soft front? Reckless Rat SV Talk, Tuning & Tweaking 8 03-05-06 06:00 PM
