Old 13-06-06, 02:49 PM   #1
The Mass
Default What could this be?
I've managed to adjust the clutch, so it's not slipping.
However, when on a long journey, like this morning, I stop for petrol, to refill, and when I get back on to ride off its really clunky getting into gear up or down.
but when I pull the revs on, she goes easily or or down the gears.
and then when in low revs again, she gets really clunky? is this normal?
Mass
Old 13-06-06, 03:46 PM   #2
When you say 'adjust' if what you did was move the cable adjusters, then what you may have done is adjust the cable - not the clutch.
Try this:
Originally Posted by I Previously
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
