Old 30-06-06, 07:24 AM   #1
SpankyHam
Default Replacing the Carbs - easy Job? need balancing ?
I will get a set of used Carbs(10k miles) with dynojet stage 3 on the weekend.
Is it an easy swap ? Anything to look out for ?
And will they need balancing ?
Old 30-06-06, 07:30 AM   #2
Viney
Easy enough to change if you are spanner minded.
A few things to look out for
Remove the choke cable at the handlebar end and thread it through the frame, and not form the carbs. Keep an eye on where the cable splits in 2. The tip of the plastic housing is very very fargile!
The carb screws that hold in said choke cable will disitergrate, so either get some replacments, or use an impact screwdriver and gentle taps(my method)
Make note of which way round the throttle cables go.
They couldnt do any harm being balanced/checked
Remember that you have the idle screw adjuster thingy to unclip and thread through.
Thats all i remember form the 1st time i took mine off. I will also be doing it this weekend to the girlfriends bike replacing the choke cable.
Enjoy
Old 30-06-06, 07:32 AM   #3
Definately balance - they'll have been adjusted to suit whatever motor they previously inhabited, most unlikely to be right - never know your luck though, stranger things have happened.
Old 30-06-06, 10:17 AM   #4
454697819
Enjoy
thatll be fun then... if uts anything lik emine was you will have to ruin the old cable pulling the choke plungers out,
no wonder it used to idle at 500 rpm or 2000....
Old 30-06-06, 10:24 AM   #5
The choke screws can be an absolute sod... I'd have replacements laid in for it, even if they come out they'll likely be mungled. They're M5x12, if memory serves.
Old 30-06-06, 11:07 AM   #6
454697819
you did forget to add, dont whatever you do buy suzuki ones, as i have it on good authority they purchased the materials for there screw manufacturer from asda deli,
Oh,, and you will need a bigger hammer, regardless of the one you currently have..
Old 30-06-06, 11:50 AM   #7
SpankyHam
Thanks for the replies.
Sounds more complicated than i thought
Old 30-06-06, 12:00 PM   #8
Marshall
now thats what im talking about, there no such thing a 'cant do' there always a bigger hammer
Old 30-06-06, 05:42 PM   #9
Nah, it's not that bad. The best bet, if they've not been touched before, is to undo them at the control end and remove the carbs with them still attached- makes it much easier to do battle with the carbs once they're off the bike. But it's sensible to plan for trouble.
Balancing Carbs/Throttle bodies tomjones2 Bikes - Talk & Issues 6 06-07-07 10:07 AM
Carb balancing the easy way SpankyHam SV Talk, Tuning & Tweaking 8 18-08-06 04:23 PM
Applying vacuum to the fuel tap for balancing carbs? kciN SV Talk, Tuning & Tweaking 10 16-05-06 03:27 PM
carb balancing Banus SV Talk, Tuning & Tweaking 9 23-02-06 01:38 PM
Balancing your carbs Sir Trev SV Talk, Tuning & Tweaking 11 08-08-05 08:35 PM
