I was testing out my braking limits on the front and back the other day, just to get a feel for how the the brakes respond on their own but I had a problem with getting stuck in gear after braking hard on the front.
After coming to a stop in 2nd or 3rd gear, it didn't want to shift down unless I let the clutch out slightly whist pressing down on the gear lever. Is there a problem with all the fluids being flung forward under hard braking or something? Don't know if this is something to be concerned about or not? Oh yeah, it's on a 2001 curvy S ![]() |
I doubt it's to do with your braking... More that bikes don't like shifting gear while stationary- even being slightly out of adjustment can cause problems.
Yeah, it may need adjusting a little. Although I tried the hard braking a few times and the gear problem was consistent. Only very rarely have this problem under normal circumstances. I was woried incase the gearbox was losing lubrication or something. Wouldn't want to damage my pride and joy
Does it happen if you're still moving?
Dunno
![]() I'll try it again tomorrow and see what happens if I let it roll a bit. |
The Sick Man
Also were you trying to change gear imediatly after braking before already applying some power or had you already applied power then decided to change gear.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
I was effectively doing an emergency stop but only using the front brake. So after I had stopped I was trying to put it down into 1st to be ready to pull away again. I have a totally standard fork set up and there so the bike dives a bit then bounces back up once stopped
Once I had released the clutch a bit it was fine till the next time I tried the hard braking then the same thing happened again. I haven't had the problem from braking hard whilst riding without actually stopping but i'll to some more testing today and see if I can narrow it down. |
Even if you are doing an emergency stop, you would pull in the clutch at the last moment though
#9 |
Not unusual as you are using engine braking as well as wheel braking and letting the clutch out a tad to drop down the box is normal practice.The gear seems to mesh/lock in harder while under braking. I have had this on my SV,Kawasaki and Triumph so it appears a common trait on any if not most bikes and not worth worrying about
#10 |
I have found it easier to be in the wrong gear on my SV because it pulls away from any gear due to the torque. When I have had other bikes, you just can't get that kind of thing wrong. Therefore I have found myself in a similar situation, if it wasn't for the neutral light I wouldn't know where I was sometimes when I have stopped at the lights.
And especially if I have braked hard, the gears do require a blip on the throttle and a bit of clutch to get them moving. I would suspect it is a normal feature of bike gears. |
Very hard to change gears | humillard | SV Talk, Tuning & Tweaking | 18 | 25-04-09 08:26 AM |
gears | clunie01 | SV Talk, Tuning & Tweaking | 4 | 10-02-09 02:22 PM |
I might be sticking around, so hello everybody | mark grinyer | Idle Banter | 18 | 29-09-08 04:05 PM |
Gears | Taylor1975 | SV Talk, Tuning & Tweaking | 1 | 29-03-08 01:23 PM |
Sticking reg/reg? | northwind | SV Talk, Tuning & Tweaking | 16 | 29-01-06 11:25 AM |
