Old 18-09-06, 08:32 AM   #1
TSM
The Sick Man
TSM's Avatar
Default Semi Dead Bike
Well just geting some ideas so when i get home i can sort this out properly.
Basicly i have no speedo/tacho/indicators/horn, everything else headlight/pass&highbeam/starter works and bike starts fine.
I have checked the 3 connectors for the front loom and they seem fine, i am thinking either loose connection behind headstock for the ignition switch part of the loom or a multiple blown fuse situation.
I did lift the tank on the weekend and also the front seat, but it was working after and i went on a ride. I will do a better check when i get home.
Old 18-09-06, 08:35 AM   #2
svrash
Check the loom just under the seat, that's were mine frayed and cause similar problems
Old 18-09-06, 08:43 AM   #3
Sudoxe
Default Re: Semi Dead Bike
Ok, this might sound drastic, but its a 3 step program:
1) Undo every bolt on your machine, remove all major components.
2) Put all components on ebay.
3) Buy something that is in once piece?
Dan
Old 18-09-06, 08:45 AM   #4
TSM
The Sick Man
TSM's Avatar
Dan
I have considered it.
Old 18-09-06, 07:09 PM   #5
TSM
The Sick Man
TSM's Avatar
Phew, it was the signal fuse in the end. It was the first thing i tested. Why it went i dont know though.
While i was at it i also sorted out the rear brake switch and put two leds in the rear tail light for the number plate, it does not light it that well though, mabey another 2 at a later date.
Dead Bike. Grinch SV Talk, Tuning & Tweaking 21 07-01-09 11:52 PM
My bike is dead shonadoll Bikes - Talk & Issues 12 14-08-08 10:08 PM
Dead Bike... MidgetMoose Pennine Massive 6 07-09-07 07:22 AM
Bike dead Red ones Bikes - Talk & Issues 17 15-05-07 06:22 PM
Dead Bike chris SVK3 Bikes - Talk & Issues 5 07-06-05 04:54 PM
