Should I just ( as I did last time...) cut the wires for the old indicator stalk then attach the new indicators using a soldering iron & tape?
Or should I remove the fairing & find out where the indicator should properly go in to the light socket thnigy?! Ta Dirk. p.s. Soldering iron is warming up as I type! |
Cut the wires and use bullet connectors so then you can disconnect them if you have to take the faring off!!
Thats what I did...
i did'nt......good
cut the wires.
No idea whataa bullet connector is. The next time I get indicators (to make front & rear match...) I'll get the garage to do it. They can fix the mess I made! ;o) |
I cut the original plug thing off the standard indicators and soldered it on the new ones! If I need to remove fairing little plug things just unplug
Fitting new indicators | neilhatch | Bikes - Talk & Issues | 2 | 13-10-08 12:59 PM |
Evotech fitting + mini indicators up front | Miles | SV Talk, Tuning & Tweaking | 4 | 29-05-08 05:40 PM |
fitting mesh to front opening on curvey lower fairings | adam_castell | SV Talk, Tuning & Tweaking | 3 | 27-02-07 04:22 PM |
Fitting front mini indicators | JakeRS | SV Talk, Tuning & Tweaking | 11 | 09-05-06 05:45 PM |
Remove front indicators space -Move indicators in headlights | JanGoris | SV Talk, Tuning & Tweaking | 5 | 19-04-06 09:27 PM |
