Old 13-10-06, 06:36 PM   #1
boycy123
Default cutting out when stood
im having problems with my k3 it keeps cutting out there is no pattern to it at all i can ride it perfectly for miles and miles then just come to a stand still ,go to give it some gas to go and it just dies, it will fire straight back up but if i let revs drop below 3000rpm it dies again eventually it will tickover and go like i say there is no pattern at all it does it cold or when i have been in her for hours and sometimes it doesnt do it at all please help!!!!!
She rides perfect otherwise...
Old 13-10-06, 06:52 PM   #2
mines done this once before but only the once so i aint really looked into it.
Old 13-10-06, 07:14 PM   #3
I'm_a_Newbie
Hi.
Have you tried the TPS check and adjustment see link http://forums.sv650.org/viewtopic.ph...&highlight=tps
This will also provide fault codes if anything is wrong with the engine management.
Kind regards
Tim
Old 22-10-06, 02:33 PM   #4
boycy123
Default tps check
done the tps check it my bike was putting fuel in at 3700rpm did adjustment to 1450rpm cured cutting out runs sweet as a nut thanks saved me a packet reccomend this easy adjustment to all....
why does my oil light stay on when the bikes stood? kwak zzr Bikes - Talk & Issues 26 08-11-09 10:00 PM
Cutting Out FlyinCustard SV Talk, Tuning & Tweaking 44 09-05-09 03:16 PM
Cutting out.. MidgetMoose SV Talk, Tuning & Tweaking 4 25-11-06 06:22 PM
cutting out 01 sv650s SV Talk, Tuning & Tweaking 2 04-11-06 11:13 PM
Cutting out The Basket SV Talk, Tuning & Tweaking 1 19-03-06 08:46 PM
