Old 15-10-06, 09:25 AM   #1
Warren
Default fitting an electric device to the bike
i got an inforad,
now trying to fit it to the bike, i could wire it directly to the battery, but it would drain it as there is no on/off switch.
so how would i go about wiring it somewhere else as so when the ignition is switched off, the inforad has no power running to it ?
it draws 5A (whatever that means)
please keep it basic, i have no clue about electrics, all i know is, i have a posive wire and a negative wire to attach somewhere.
this isnt an SV by the way, its a CBR, but i imagine the wiring should be pretty similar
Old 15-10-06, 09:51 AM   #2
weazelz
Default Re: fitting an electric device to the bike
does it hve a 60W bulb in it?
Old 15-10-06, 03:55 PM   #3
Heed
5A is 5 amps which means you'll need to allow for this with the fusing if you splice it into a current electrical system.
Old 15-10-06, 04:55 PM   #4
ugp
If you look on the underside of the fuse box, there is a space for extras to be wired in. The orange wire has a bridge into an empty connector, this orange wire is only live when the ignition is on. You can solder the positive to this wire and not risk draining the battery.
Hope this helps
Ben
Old 16-10-06, 05:16 PM   #5
Warren
urr, thanks so far,
i kinda get what your saying,
ill get the manuals out.
ive got a mulit meter, but havent a clue how to use it.
im dying to learn.
right,
the device im trying to fit, is an inforad speed camera detector,
im confident i can wire the rest of it up to the antenna ect ect, but im not so confident with the giving it some power part.
the only advice the manual gives as regards to fitting is
INFORAD requires an electrical power source of 5 to 24V (500mW) provided through the cable (5).
fit the red cable to the positive and the black cable to negative or earth.
the bike is a honda CBR, i have the wiring diagram infront of me, but dont really understand it.
the current bulbs i have in my bike, are a pair of 12V 55W H7 headlight bulbs,
one is dipped beam, and the other is full beam .
what now ?
Old 16-10-06, 05:25 PM   #6
jim@55
most things have just two wires ,one live feed and one earth .easy .just find out what wire to tap into for a liv feed (only when the key is in is best ,not live constantly ,cos it may drain ur batt) and connect the other one (usually black)to an earth or run it straight back to earth terminal on the batt ,tidy up wiring ,jobs a good'un
Old 16-10-06, 05:28 PM   #7
jim@55
and btw dont concern ur selv with the lights/bulbs a wee bit of **** taking i think pss it really doesnt matter which bike ur talking about ,most are broadly similiar -12v and an earth ,its not rocket science
Old 16-10-06, 05:30 PM   #8
Warren
cool,
for some reason my rear bulbs seem to blow every few months, ive had this with every bike ive owned, and im not sure why.
Old 16-10-06, 05:39 PM   #9
Warren
so you recon if i was to wire it like this, i would be fine ?
Old 16-10-06, 05:50 PM   #10
jim@55
yeah, i think so ,but if it was me ,i would run the earth wire back to the battery ,ul get a much btr connection that way (and itl have its own earth wire)most elec faults with accesories are the earth ,so do urself a favour and run it back
New electric bike - 100lb/ft @ 0rpm!!! thor Bikes - Talk & Issues 44 05-02-09 11:34 PM
World's fastest all electric bike? missyburd Bikes - Talk & Issues 6 28-11-08 04:05 AM
Electric bike anyone? lazymanc Bikes - Talk & Issues 13 27-10-08 05:30 PM
Electric Addons on Bike 600+ Bikes - Talk & Issues 4 29-12-07 06:45 PM
0-60 in 0.97 second 158mph electric bike SoulKiss Bikes - Talk & Issues 15 17-09-07 04:35 PM
