Old 23-11-06, 02:34 PM   #1
Default mini indicators
my mini indicators flash fast? the bike passed an mot last week so it cant be that bad i'd just like to slow them down alittle, any ideas? i dont know if there normal bulbs or led's?
Old 23-11-06, 03:04 PM   #2
hovis
you need a relay resister thingy
Old 23-11-06, 03:06 PM   #3
hovis
Led Flasher Relay.
Details
If you've customised your bike with LED indicator lamps then the chances are they flash too fast to pass the MOT. Simply fit this wide range flasher relay and guarantee the correct flash rate whatever indicators are fitted.
SEE HERE
http://www.busters-accessories.co.uk...sp?id=451&pg=2
Old 23-11-06, 04:21 PM   #4
thourght that was only led's tho? i dont think mine are led but couldnt be sure.
Old 23-11-06, 06:59 PM   #5
suzsv650
u jsut need a resistor on each indicator not sure what ohm it is should think itl go on the positve you could jsut buy a bunch and find out which one works better i wouldnt bother with the indicator its like £30 for a resistor that costs Pence.... some one much know the corect one
Old 23-11-06, 08:09 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
They look like motrax tinycators they use a 12v 6w bulb they're not LED
2001 SV650 in shimmerin green, Not broken anymore
dirtydog is online now   Reply With Quote
Old 23-11-06, 08:23 PM   #7
any idea why they would be flashing fast?
Old 23-11-06, 08:53 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
I think it may be cos the bulbs are only 6w whereas i think most indies are 10 or 21w so if i'm right that would mean there is not as much load on the indies so it's like having a bulb out
Old 23-11-06, 09:48 PM   #9
lucky strike
Kwak, those are the Eagle eye range are they not?! Very nice I must say, but too pricey for my thin wallet! They run 12v bulbs iirc, but they flash fast due to resistance/current changes from stock part caused by lower power output on these bulbs.
I fitted a resistor of 25w and 10 ohms resistance on mine. These are the metal bodied 'power resistor' range, not the cheaper ceramic/plasticky type! Bought from RS. Maplins do sell them, but I think they only go up to 15w or something if memory serves me correctly.
Please read this thread, as it explains things better than me!
http://forums.sv650.org/viewtopic.ph...ghlight=sparky
Good luck buddy
Old 23-11-06, 10:20 PM   #10
is it all worth the hassle?
R&G mini indicators robertjp SV Talk, Tuning & Tweaking 2 24-08-08 08:52 AM
mini indicators lancasterlad Stuff Wanted 0 13-07-07 11:21 AM
Mini indicators... PaulyMac SV Talk, Tuning & Tweaking 3 11-10-06 10:20 PM
LEd indicators mini ones at last !!! Quiff Wichard Photos 25 30-04-06 09:51 PM
Mini indicators Jebiah Bikes - Talk & Issues 2 27-03-06 10:52 AM
