Old 07-12-06, 08:43 PM   #1
jimmybluedevil
Default linkage/shifter help
Hey folks Im experiencing a slight problem. Today I rode to work as usual with nothing out of the ordinary. I left for lunch and when I arrived at the restaurant I couldnt get it out of gear! Didnt want to shift up at all. Finally got it in neutral but it was sticking a lot. I found that the nuts on the linkage were a bit loose but tightening them made it worse. As soon as I got it on the street it was fine while riding but had trouble again when I parked.
Oh I adjusted and lubed the chain 2 days ago
Any ideas?
Old 07-12-06, 09:16 PM   #2
Searching brings:
Originally Posted by Sid Squid Previously
The problem is most probably the lever pivot being a bit sticky. The change mechanism isn't able to reset itself between gears, if you lift the lever with your foot between changes it should work fine.
To fix it properly:
Remove the lever from the footrest and remove the fibre bush from inside the lever *very carefully* - the bush isn't available seperately and it's easy to damage - if you look close you can see where the bush is split, gently get behind it and roll it up a little you'll be able to pull it out, if you look inside the lever you'll see where corrosion has built up behind the bush, expanded, and squeezed the lever onto the footrest pivot, causing oit to drag, if you gently scrape away the corrosion smear the area with a little grease so it doesn't corrode so easily and reassemble it should be fine.
Old 08-12-06, 02:35 PM   #3
jimmybluedevil
Thanks a million Ill try that today
Old 08-12-06, 04:10 PM   #4
jimmybluedevil
figured it out- my clutch is starting to go
Old 08-12-06, 04:26 PM   #5
Viney
and how have to come to that deduction?
Try adjusting/replacing the cable, clean and greese the lever pivot on the handlebar, before making that decision. Also check clean and grease the worm drive on the clutch as well.
HTH
Old 08-12-06, 08:48 PM   #6
jimmybluedevil
HTH
Yeah it was the cable. I tightened it but found it was frayed by the lever so I took it in to my shop and had them replace it. Thanks for the help. Phew
Goodby Gear shifter :( hob SV Talk, Tuning & Tweaking 7 18-11-08 05:29 PM
Is it not possible to get the gear shifter off the footpeg assembly? Jase22 SV Talk, Tuning & Tweaking 3 17-08-08 06:15 PM
green plug in frame, above shifter oconnor SV Talk, Tuning & Tweaking 6 29-01-07 07:56 PM
Gear shifter linkage rod Razor SV Talk, Tuning & Tweaking 5 05-01-07 11:26 PM
Clip-on, upper fairng, and shifter unit. ruf_rider SV Talk, Tuning & Tweaking 1 04-08-05 11:26 AM
