Old 14-01-07, 07:54 PM   #1
Mark_h
Mark_h's Avatar
Default Fitting DL650 handguards
I know there have been some previous threads on the subject however laziness prevents me searching them out and either extending or linking to them.
The other day I fitted a pair of DL650 guards to my old naked curvy. Went out today with my heated grips set to half heat and my summer gloves on and was toasty warm. Even turned the heater off once the sun got up a bit. Much comfier than fighting with winter gloves and still getting freezing fingertips.
Probably not the most attractive accessory to fit to a bike, but if you want to extend your riding season can not recommend them highly enough.
If you plan to fit them, it's quite straightforward, but I did have to move the lever mounts inwards a bit as the left hand one caused the choke to foul the guards and the right hand one ended up with the guard about half an inch too far away from the end of the grip.
I would also suggest you readjust your clutch cable correctly before fitting the big plastic bits as it is a bit fiddly getting to the adjuster once you've got the guards fitted.
Oh and get the kit for the DL650 at about £23. As the 650 kit comes with all the fittings. The DL1000 kit is just the guards and you need some very specific bolts to make it all work.
Cheers,
Mark
Minister for Sustainability
Old 14-01-07, 08:42 PM   #2
Tim in Belgium
Sounds very good and useful. My winter gloves are horrendous to ride in.
Will they work with clip ons, like a curvy S?
Old 14-01-07, 08:48 PM   #3
ejohnh
Where did you get them Mark?
John
Old 14-01-07, 08:56 PM   #4
Carsick
They go happily on the faired SV.
I'd just like to note, they do handle minor crashes well, if you don't mind the scratches.
Old 14-01-07, 09:59 PM   #5
Mark_h
Mark_h's Avatar
If you search through the history, one of the other Guildford riders, Stu posted some pictures of a pair fitted to his faired bike. They look a lot better on a pointy than a curvy, but either way they keep your hands warm.
They are a genuine Suzuki part. I got mine from local dealer www.Infinitymotorcycles.co.uk I expect any decent dealer will be able to get them for you.
If you manage to track down Stu's posting he had the part numbers too. If I manage to find my paperwork I'll add the part numbers to this thread.
Fitting Acerbis handguards. Ruthja2801 SV Talk, Tuning & Tweaking 5 24-03-10 09:14 PM
DL650 Handguards - LH slightly damaged Nobbylad For Sale - Other Bikes and General biking items 5 05-03-09 01:22 PM
DL650 V-Strom handguards on a SV650 Lozzo SV Talk, Tuning & Tweaking 58 09-12-08 06:32 PM
DL650 cables on an SV650 K6 N ? gomez SV Talk, Tuning & Tweaking 1 15-01-08 07:49 PM
DL650 rpwoodman Bikes - Talk & Issues 10 30-08-05 09:33 PM
