ok rang pdq about fitting will have to cut spacers once i work ot the sag put the forks in the bike but now they wont compress for some reason they are fitted correctly on top of the damping rod holes are drilled out of damping rod so why dont they compress any ideas
The Sick Man
Err can you put punctuation in that rambling as its just a muddle of words.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
ok i fitted emulators as it said in the manual but now they dont compress any ideas
The Sick Man
when you put the fork oil in, did you mesure the air gap on your forks with the spring out and compressed?
yes measured 130 mm from top of fork tube with forks compressed and no spring fitted
The Sick Man
when you say dont compress, are the completley locked or just very hard to compress?
Is there any chance you put the emulator the wrong way around? Have you dismantled the forks and checked that everything is ok
there is a very tiny amount of gice about 5mm they are in the right way spring on emulator going up the fork tube towards the top nothing seemed untoward when i stripped them
Take every thing out, put a broom handle (wooden) down the inside of the leg and give it a tap with a hammer, put every thing back in when the leg is out again.
Mine used to stick down every time i changed the oil and seals ![]() |
#9 | |
My guess is that you have an obscene amount of preload ... |
#10 |
took 8mm off original spacers but it took some effort to get caps back on
Racetech emulators | natcar | SV Talk, Tuning & Tweaking | 58 | 31-10-07 12:36 PM |
emulators? what are they? | Mossy | SV Talk, Tuning & Tweaking | 3 | 18-05-07 04:34 PM |
racetech emulators | weazelz | SV Talk, Tuning & Tweaking | 23 | 02-10-06 10:43 AM |
Emulators | RingDing | SV Talk, Tuning & Tweaking | 27 | 07-07-06 07:49 PM |
Emulators? | Jester666 | SV Talk, Tuning & Tweaking | 6 | 06-07-06 08:17 AM |
