Old 12-02-07, 08:42 AM   #1
tee jey
Default Question - Free play in swing arm pivot
How much free play is acceptable in the swinging arm bearings?
With the wheel out and shock and cushion lever removed I have slight movement between the right hand pivot spacer (item 7 on the exploded diagram of the assembly) and the swing arm (10) which translates to about 2 to 3 mm side to side movement at the wheel end of the swing arm.
If the swing arm pivot shaft was not tightened to the correct torque (15 Nm) could this result in free play? i.e. is it worth undoing the lock nuts and checking the torque setting on the pivot shaft?
And finally, if the swing arm pivot bearings are shot, how much am I looking at to have them replaced?
The bike is a K3 pointy with 18k.
Old 12-02-07, 10:29 AM   #2
andy
Default Re: Question - Free play in swing arm pivot
That sounds like a lot to me - is it rocking on the pivot shaft or simply sliding from side to side?
Old 12-02-07, 11:41 AM   #3
tee jey
I think it's rocking.
Old 12-02-07, 12:36 PM   #4
Yep, that really doesn't sound right to me...
Old 12-02-07, 05:06 PM   #5
kcowgergmm
i am thinking of seeing if i can fit a Nt650 single side swing arm on to my sv does this seam like a good or a bad idea to you all
Old 12-02-07, 05:18 PM   #6
I bet you a pound it won't fit without a load of work...
Old 13-02-07, 01:15 PM   #7
andy
They are f*cked then, unusual for swing arm bearings to go on a road bike.....
Old 13-02-07, 03:03 PM   #8
jambo
jambo's Avatar
It may be worth tightening it up to the correct torque (We may be at cross purposes here but IIRC on the ZX6 the swing arm nut is tightened to something like 110Nm).
When lifting and lowing the swing arm it should move smoothly without notchiness or feeling like it's being urned through cement / gravel. There should be no lateral movement.
HTH
Old 13-02-07, 03:08 PM   #9
Viney
Agreed. mines at 50k with no play
Old 13-02-07, 03:08 PM   #10
Viney
Try an NC30 arm...i think. Still lots of work
New free to play Fantasy MotoGP game Colby Bikes - Talk & Issues 1 30-01-08 09:37 AM
Fantasy BSB competiton - Free to play Colby BSB & WSB 0 20-03-07 10:55 AM
rear subframe+swing arm k4 free mart For Sale - SV's and SV related items 3 23-02-07 07:01 PM
Throttle free-play Jabba Bikes - Talk & Issues 18 29-08-06 01:15 PM
how to adjust clutch free play steveg SV Talk, Tuning & Tweaking 7 25-04-06 10:29 PM
