Old 03-04-07, 01:02 PM   #1
DanDare
Default Clutch Lever
Hi y'all,
Just had my K4 serviced and my ride back I noticed the clutch bites later than I was used to. Ie: When releasing the clutch lever it doesn't bite until its almost fully released. It took some getting used to, is there a simple tweak to get it to bite about half way through the motion of releasing the clutch handle?
Cheers in advance
Dan
Old 03-04-07, 02:13 PM   #2
andyaikido
Default Re: Clutch Lever
Should be able to do that from the lever end of the cable.
Move the rubber cover, loosen the lock nut (big round one) and then adjust the smaller one so it's how you like it. Then tighten the lock nut again.
Or search for "clutch adjustment" and do it properly.
Old 09-07-07, 08:50 AM   #3
knirirr
Apologies for the basic questions, but which way should the big nut be tightened? Presumably towards the smaller adjuster? I found it loose today after encountering exactly the same situation as the OP (bite point moved forward after service).
Also, which way should the smaller adjuster be turned?
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
need clutch lever and a gear lever! matt90 Stuff Wanted 0 23-11-07 02:08 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
