I loosened my wheel nut the other day to adjust my chain a little, and when i tightened it back up the metal thingy that guides the oiler tube onto the chain spun round and now its all out of allignment.
I can keep it still up to abot 80Nms, but then i try to tighten it up to 100 as per mannual, everything gets really tight and there is no way i can stop the oiler thingy from moving round. Any suggestions. ![]() |
is it underneath or on top of the washer? mine is underneath, & i can just hold it in place
Knob faced knobster
But yours is a curvy which only needs to be torqued upto 64Nm New Leaf has a pointy which is meant to be torqued upto 100Nm
2001 SV650 in shimmerin green, Not broken anymore |
Mines a curvey too (a naked one) and my owners handbook says 100Nm - i think.
I better get my butt out of bed and go and check!! I'll also look to see if its under the washer or not. Thanks guys. |
Knob faced knobster
Just checked suzuki state a curvy rear axle nut should be 65NM
oops - thats what my haynes book says too.
if i loosen it back to 65 do u think i will have done any damage? |
#9 |
Knob faced knobster
![]() I took it at being a pointy cos i think that is what their axle nut is meant to be torqued upto something daft like 100Nm
#10 |
I think 100NM is stupid tight too. 80 should be enough. Unless it's supposed to be 64NM, in which case, happy days. I doubt you'll have done any major damage to the swingarm by over tightening. Maybe dug into the finish a bit, and your chain might need re-adjusting.
My CBR is supposed to be torqued to 113NM! ![]() I can't even get to torque wrench to click out when it's set that high. |
Ok stupid question | aarond | SV Talk, Tuning & Tweaking | 2 | 19-05-07 04:47 PM |
stupid question | lukemillar | Bikes - Talk & Issues | 34 | 28-03-06 06:17 PM |
Stupid question??? | Ash999 | SV Talk, Tuning & Tweaking | 1 | 22-02-05 07:21 PM |
Stupid question..... | Jabba | 2005 Annual Rideout | 7 | 21-02-05 02:24 PM |
Stupid Question ? | Rodger Wabbit | SV Talk, Tuning & Tweaking | 7 | 13-10-04 08:15 PM |
