Old 16-04-07, 09:47 PM   #1
cdrsimmonds
Question Sprocket Nuts
Hi, does anyone else have trouble tightening the nuts on the rear sprocket carrier to the correct torque setting? I remember when i changed the chain and sprockets on my old GS500 one of the bolts cross threaded due to the large torque setting, and when we changed the rear sprocket on my friends race bike (GSXR600) the nuts will only go upto about 65nm (before cross threading (manual says 93nm!) How do you find the best method of final tightening?
Regards
Chris
Old 16-04-07, 09:59 PM   #2
Stig
Default Re: Sprocket Nuts
I don't use the torque wrench.
I put them in using socket and ratchet. I also use locktite blue. Haven't had a nut come loose on me so far.
Old 16-04-07, 11:01 PM   #3
It's 60nm for the curvy... Don;t have a pointy manual but I'd imagine it'd be similiar, they're the same overall design if not the same part.
Old 17-04-07, 07:57 AM   #4
John Burt
were you using aluninium nuts with the steel thread insert or standard ones, both stainless steel and the ally ones will not torque up the same as the oem ones - less tensile strength. Don't ask me about Ti though as I am too tight to splaash out on those.
Old 17-04-07, 06:54 PM   #5
cdrsimmonds
Originally Posted by John Burt View Post
were you using aluninium nuts with the steel thread insert or standard ones, both stainless steel and the ally ones will not torque up the same as the oem ones.
We used OEM ones over the weekend, we were reusing the original ones despite the manual saying to always replace them. The guys in the paddock said just to use loctite to compensate for the loss of the self sealing ability.
The main problem is the final torqing. To get to such a high torque setting requires the use of a long torue wrench which, on such a small nut, tends to wonder under pressure rather than tightening square on. Do you guys torque up with the wheel or sprocket carrier loose or with the wheel mounted to the bike?
Old 17-04-07, 07:30 PM   #6
Not being funny but are you sure you've got the figures right? Just checked the manuals I have access to, and the curvy and pointy SV, GSXR SRAD and Bandit 12 all call for 60nm on those bolts.
Old 17-04-07, 08:12 PM   #7
cdrsimmonds
I only do what my friends manual says to do i've put the page in question here... (hold Ctrl and scroll your mouse to enlarge image)
http://homepage.ntlworld.com/chrissimmonds/gsxr.jpg
Old 17-04-07, 08:34 PM   #8
Fairy dos...
Old 17-04-07, 08:44 PM   #9
same here, suzi bolts are ****e so do it by feel.
Old 18-04-07, 11:39 AM   #10
cdrsimmonds
Concidering the almost impossibillity of the task do you reckon 60nm is enough as the bike this relates to is my friends race bike so i takes a tiny bit more punishment than its road going equivalent....
Where to get rear sprocket nuts quickly? manicmonkey SV Talk, Tuning & Tweaking 12 02-03-09 01:33 PM
Rear Sprocket Nuts Scoobs Bikes - Talk & Issues 5 23-03-06 08:27 PM
Only if your nuts Dicky Ticker The Essex Lounge 5 20-11-05 03:00 PM
Rear Sprocket Nuts And Bolts sv182 SV Talk, Tuning & Tweaking 5 21-12-04 11:16 PM
Oh Nuts! admin SV Talk, Tuning & Tweaking 19 14-11-04 05:21 PM
