Old 28-04-07, 11:05 PM   #1
mclarenmike
Unhappy Swingarm damaged - advice needed!
This happened today at the tyre fitters:
Can anyone recommend what I should do to get it fixed? (I'm not a mechanic!!) Help!
Old 28-04-07, 11:12 PM   #2
Dan
Default Re: Swingarm damaged - advice needed!
I'd be asking the tyre fitters to sort out the mess they made.
Old 28-04-07, 11:17 PM   #3
mclarenmike
The guy said he'd pay the bill for whatever work I need to get it fixed. Although he did try and discourage me from going to the local suzuki dealer!!
Old 28-04-07, 11:42 PM   #4
Richie
fantabulas
Richie's Avatar
I'm a mechanic and I did the exact same thing myself, Can't be helped sometimes. Note to Self...( should have put the other spanner on the other side of the axel, as nut tends to seize on the axel bolt and turn it...)Doh.
My Flickr photos
Old 29-04-07, 09:09 AM   #5
SoulKiss
SoulKiss's Avatar
I think loosing your numbers = loosing your marbles
You say it cant be helped, but then go on to say how it would have been avoided?
It was early I suppose :P
David
Old 29-04-07, 09:58 AM   #6
Born again
If the guy doesn't want you to go to a main dealer get a quote else were and see what he says then, you could always price up a new arm, add a bit for your labour and do it yourself and give him the bill.....
Old 29-04-07, 07:53 PM   #7
andyaikido
The mechanic needs to sort that out but I don't know of a cheap fix.
When I did that to mine I touched it up with a satin black touch-up paint but it won't blend like paintwork does. I think the swingarm is anodised.
Old 29-04-07, 11:27 PM   #8
Ratty
Ratty's Avatar
Note to anybody trying to un-do the rear axel on their own. Buy a couple of cheap small G clamps off the market and clamp each adjuster plate onto the swinger (without over tightening), before un-doing the axel nut. Prevents this damage.
Al
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Advice needed Dicky Ticker TOTALSV Ireland 4 13-11-07 08:21 AM
Advice needed please aarond SV Talk, Tuning & Tweaking 0 02-10-07 05:10 PM
Advice needed rs_tubby Suits 6 07-06-07 01:18 PM
Advice on fixing damaged bodywork morty TOTALSV Ireland 1 29-05-05 06:08 PM
Advice needed 650newb Exhausts 4 06-12-04 10:40 AM
