The SV has felt a bit odd riding for the last few times, especially on the front end. This evening I noticed that the forks/whole front end can be bounced up and down very easily - several inches up and down with just me getting on and off. Is it because I've put on a few pounds or could it be that they're losing damping? There's no sign of oil loss around the forks and it's a K4 with under 9000 miles
![]() The springs still go up and down, I'm sure they used to not go down that far when they were under load though. |
Have you been eating lots of pies?
Yes I have been eating pies.
No the weather wasn't noticeably warmer when they felt like they'd lost damping. They were back to their normal selves this morning, not as bouncy and felt fine. Bizarre. I'm expecting them to be rubbish again this evening... can a few degrees C make that much difference?? |
I would guess that the oil in the forks has never been changed. Considering that it's a K4, that's now over two years. Time to change the oil.
I've noticed, that now the weather has got warmer, that my front suspension is squidgier. A few degrees can make a bit of differance, it seems!
Actualy, i've been pondering - and this is a bit off topic here - about the feasiblity of fitting GSXR600 K1 front forks (right-way up forks, like the SV, but far better) to my SV. I dont want upside downies, as i want to retain the look of the bike, but I do want a bit of a firmer front end and some adjustment options Matt |
#7 | |
#8 | |
The Sick Man
SRAD tripples and K1-3 forks plus calipers for them, all you need to do is shim out the calipers by 2mm with two washers. Use an axle from SRAD series as they are a little longer, wheels are the same srad to K3 and disk are same too.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#9 |
I've opened up a few sets of forks to find the oil been emulsified! Fresh oil has restored the dampoing action nicely. So if me were thee I'd drop the forks and change the oil.
#10 |
I have a similar problem with my Curvy, I did the springs and oil at about 10,000 miles, and now at 23,000 I am sure the damping has gone (although it may just be that I am used to my TLR and that is why I think it), anyway I am sure the oil has a pretty short life so am going to change it when I get the chance.
losing a loved one. | Frank | Idle Banter | 23 | 27-02-09 09:19 PM |
Help I'm losing oil (Actually it's my bike that's losing oil). | manicmonkey | SV Talk, Tuning & Tweaking | 23 | 28-01-09 09:15 AM |
Still losing power? | Baz | SV Talk, Tuning & Tweaking | 12 | 21-12-08 06:42 PM |
Losing the limiter | ThEGr33k | SV Talk, Tuning & Tweaking | 45 | 27-08-06 12:05 PM |
Damping Rod Holes & Emulators | AlexG | SV Talk, Tuning & Tweaking | 2 | 11-07-06 06:41 PM |
