Old 31-05-07, 06:39 PM   #1
muzikill
muzikill's Avatar
Default Chain oil - cheap!
My mate has a chainsaw for cutting down trees and i happened upon him oiling the chain, now this stuffs 3 quid for 2.5L - 3L in a normal anti freeze type container and looks, feels and smells exactly the same as 'bike chain oil'
The only problem is that it cannot be sprayed straight away
Can this be used?
If so all you have to do is put it in a large 'spray' bottle to use it
And you could put some in a smaller bottle to put under the seat for use on long journeys
Just head along to a local tool merchants and check this stuff out.
Old 31-05-07, 07:54 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Chain oil - cheap!
Just keep and use the stuff you empty out of your engine when you change that oil.
That way its free
Old 31-05-07, 08:14 PM   #3
Biker Biggles
Biker Biggles's Avatar
Quite right.
Recycle it.
Old 31-05-07, 08:20 PM   #4
Spiderman
Where the hell am I?
Spiderman's Avatar
Yup, what they both said.
Obviously flings off more than lube made specificaly for the job so you gotta apply it a bit more frequently but i do use my old engine oil on my chain after ive given it a good clean.
Old 31-05-07, 08:48 PM   #5
Pedrosa
Ha, everybody be wasting opportunity here! You Englisdh people be like your chips. When oil no longer good for fry, use on chain! Cant be more cost effective than this surely?
Old 31-05-07, 09:11 PM   #6
carlos
"recycled" engine oil will seem like superglue when compared to the fling of chainsaw oil, you should see the way it flings off the guide bar. If you do use it please, please take it easy to see how you get on before pushing the bike too hard. Don't want to read about another 'off' on the forum.
Old 01-06-07, 10:07 AM   #7
Pedrosa
One of my mechanic once try Oil of Ulay. He said not work too good for chain but it smell nice and be very soft.IHTH.
Old 01-06-07, 10:10 AM   #8
Grinch
My back wheel is black from scotoiler oil... what the hell is engine oil going to be like.
Old 01-06-07, 04:18 PM   #9
How much more black? None. None more black.
Old 01-06-07, 04:23 PM   #10
Pedrosa
For real budget conscious peoples a great opportunity should not be overlook. Provided free is ear wax which can be collected over a period of time and apply generally to chain. Likely to have extremely "low fling" qualities I thinking?
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Cheap Cheap Cheap New Hugger! SAMMY650 For Sale - SV's and SV related items 9 15-05-08 02:49 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
