Old 13-06-07, 08:40 AM   #1
Taipan
Taipan's Avatar
Question Carb balancing
Hi All
I now have a Twinmax again and willl be looking to balance or at least check the carb balance on my curvy Sv tonight. I've been trawling the archives and I gather getting to the front carb vacuum is a bit of a sod? Is it a carbs off job or is there a work around?
Owt else I should know or any tips or must/mustn't do's?
Many thanks.
Old 13-06-07, 08:44 AM   #2
rictus01
rictus01's Avatar
Default Re: Carb balancing
You won't need to remove the carb, but it is a little tight access wise, remove the lower rad mount bolt and pull the rad forwards, get a length of tubing (about 4") and leave it on the front spigot with a bolt blocking it, then next time just use that, so no rad moving needed.
Cheers Mark.
Old 13-06-07, 08:45 AM   #3
Luckypants
Luckypants's Avatar
No it is not a carbs off job, but it is an airbox off job. See this on the main site for a mod you can do tp make balancing the carbs easier after the first time. You might also like to search on SVrider.com for good info on this mod.
Old 13-06-07, 09:24 AM   #4
Taipan
Taipan's Avatar
Thumbs up Re: Carb balancing
Veyr helpful advice. Thanks Chaps.
Carb balancing Grinch Soho Massive 10 07-05-09 07:44 AM
Carb balancing. scottjames SV Talk, Tuning & Tweaking 12 27-10-08 01:14 PM
carb balancing ricky SELKENT 6 22-04-08 08:11 AM
Carb balancing by ear? ikb SV Talk, Tuning & Tweaking 16 31-01-08 12:28 PM
carb balancing johndo SV Talk, Tuning & Tweaking 3 08-04-05 05:31 PM
