Old 21-06-07, 11:42 AM   #1
Grinch
Default Help - No Ignition, Lights, or Odometer (Sorted Now)
I've put the bike back together (2001 sv650s) and wired up all the wiring, stripped out the old alarm and imobalizer. But still nothing, no lights, odometer or anything, nadda. I've checked the fuses, even replacing the 30a fuse. I've even crossed the starter relay and the starter turns, but when I switch the ignition on I get nothing.
Now I'm looking through the wiring diagram and it all seems correct and I don't appear to have missed anything that would affect it, but still its a lifeless beast.
Any ideas while I double cheak it all and stare at me manual?
Old 21-06-07, 11:46 AM   #2
Baph
Default Re: Help - No Ignition, Lights, or Odometer
Dig out your multimeter & get testing voltages. It's the only way you'll find it.
Old 21-06-07, 11:51 AM   #3
hovis
is the battery ok, & connected?
Old 21-06-07, 12:35 PM   #4
Grinch
Right, just tested the ignition barrel on Helga, and it started the bike fine. Next is the relay.
Old 21-06-07, 01:52 PM   #5
Grinch
OK, put the ignition back on and pulled the relay off and that was fine, reconnected it all and now I'm sat here lisening to a SV that hasn't started in 2 years tick over.
Woohoo, Happy is I.
Old 21-06-07, 01:53 PM   #6
Law
Woohoo, Happy is I.
what was it in the end, loose connection?
Old 21-06-07, 01:53 PM   #7
SoulKiss
SoulKiss's Avatar
Woohoo, Happy is I.
You riding them BOTH to AR07?
Or is one for PJ ?
:P
Old 21-06-07, 01:55 PM   #8
Grinch
Not sure but now it works...
Or is one for PJ ?
:P
I'm riding Anastasia if I can get it all sorted in time.
What's up with the ignition? arcdef SV Talk, Tuning & Tweaking 14 17-12-08 11:15 AM
Odometer freaking out adam87sneaky97 SV Talk, Tuning & Tweaking 7 11-10-08 01:10 PM
Can you trust the odometer? phizog SV Talk, Tuning & Tweaking 14 09-11-07 10:47 PM
ignition sv 650 suzanne2869 Stuff Wanted 10 05-11-07 05:10 PM
Speedometer Out, Odometer Frozen - 2001 SV650 Naked jmoorse SV Talk, Tuning & Tweaking 4 22-12-06 10:46 AM
