Old 23-06-07, 06:51 PM   #1
600+
Default Need to borrow a Power Commander
Is anyone near Manchester on Nottingham that I could borrow their PC to upload a map on my bike please?
That's all I need to do really to get a bit more out of the SV (do correct me if i'm wrong)
cheers
Old 23-06-07, 07:58 PM   #2
lawson17
Default Re: Need to borrow a Power Commander
The Power Commander plugs in-line with the Fuel injection and TPS. So if you want to make a bit of a difference, it has to stay on the bike. It is a separate unit to the Suzuki ECU.
In other words the PC only alters the ECU original signals. So using one temporarily to upload a different map, won't work. Sorry!
Old 23-06-07, 08:06 PM   #3
Davie
Sorry to hijack your thread but is the Power Commander a worthwhile investment i don't rearly now what they do
Old 23-06-07, 08:16 PM   #4
lawson17
Power Commanders allow adjustment of fuelling to suit the bikes engine tuning/can/filters etc. Dynojet also sell modules that allow you to alter the ignition timing, energise relays and also has quickshifter capability. It helped smooth things out a bit, but not really a great deal. I had mine set up on the dyno as I thought it was best.
They are user adjustable as standard, you can upload (from your computer)various maps from Dynojets website. Or as mentioned before, you can get someone who knows what they are doing to help!
Old 23-06-07, 08:18 PM   #5
sv650nutter149
im selling my power commander!!!! not been used much!!! 70 quid including cd and 5 quid for postage.
Old 23-06-07, 08:22 PM   #6
lawson17
What a Bargain!
Old 23-06-07, 11:03 PM   #7
rictus01
rictus01's Avatar
cheers
As stated the PC is an output modifier (only modifies the ecu output.) so once removed the ECU output becomes unmodified, you're thinking of a re-map, for this you'll need a Yoshi box or tuneboy (several others as well) which write directly to the ECU.
Cheers Mark.
Old 23-06-07, 11:55 PM   #8
600+
I stand corrected - sorry peeps misunderstood the use of a PC
I obviously meant sthing that would write perm on the ECU
Old 24-06-07, 12:23 AM   #9
Baph
Ask around your local bike shops for someone with a DynoJet that has an air/fuel rig on it and can do Yoshi mapping. I know there's a place in Bradford.
Also, check here for a list of DynoJet tuning centres in Manchester.
SV650Racer said that they charge £25 for it doing on an SV, but they're the wrong side of the M25!!
Old 24-06-07, 06:35 AM   #10
600+
cheers Baph - I'll ring those 2 places Monday
power commander daddydan SV Talk, Tuning & Tweaking 30 16-05-08 10:01 AM
k3 650 power commander d8mof Stuff Wanted 1 31-01-08 06:52 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
power commander latts650s For Sale - SV's and SV related items 0 23-03-06 04:40 PM
power commander griff SV Talk, Tuning & Tweaking 10 02-06-05 04:47 PM
