Old 06-07-07, 09:59 AM   #1
sv650ninjaman
Default bike wont start very strange???
Hiya all im new to this site like 2 minutes ago and i really need ur help!!!
i was riding my 2001 sv650s yesterday and it was fine it is a really nice bike!!
started on the button as usual after doing about 15 miles i turned the bike off by the key 2 minutes later i turnd the ignition back on which it did, pulled in the clutch put up the stand and hit the starter butrton!!
all i got was a kinda spinnin sound have alot of power in battery just sounds like a spinnin wir and the engine wont fire i changed plugs like 300miles ago and as i say it has always started on the button??
could it be as simple as the starter motor??
would be very grateful 4 ur help as i have baby coming and could do without the expense of puttin it in garage as if it is starter motor its a quick fix....
cheers
Old 06-07-07, 10:02 AM   #2
Alpinestarhero
Default Re: bike wont start very strange???
Sonmetimes the carby bikes dont start so great. Have you tried giving it a whisper of throttle as you start? This helps with my 99 SV
Could be a starter motor, maybe the gears have sheard?
Someone will be along with a better, and more correct, answer
Matt
Old 06-07-07, 10:02 AM   #3
plowsie
mine does that from time to time, i turn the lights of and turn the throttle half open as i press the button and she fires.
Old 06-07-07, 10:21 AM   #4
sv650ninjaman
yh i tried all that openin the throttle slightly turned off everything tried agen nuthin ?? just sounds like a spinnin which i thought could have been the smotor threads have sheared it was very hot when i checked it just after it didnt start thanks 4 the input guys
Old 06-07-07, 10:27 AM   #5
plowsie
Could be the battery i know you say its full, but the spinning sound is the starter, i charge my battery when i hear that for half an hour and it starts fine.
Old 06-07-07, 10:33 AM   #6
sv650ninjaman
but 4 it 2 suddeny go after startin on the money every time and all the lights r on and its sounds as if the battery has a lot of power 2 it i dont think its the battery??? ill try it overnight btonight but 4 sum reason i think its the starter only because ive had 1 go on the car years back and kinda was the same just like 2 make sure??
Old 06-07-07, 10:37 AM   #7
plowsie
Well maybe you left the parking lights on for once by hackcident.
Old 06-07-07, 05:49 PM   #8
Lozzo
If the battery has lost enough charge to do that after 15 miles I'd be looking at the charging circuit, and in particular the reg/rec.
Old 06-07-07, 05:49 PM   #9
CB1ROCKET
You say its spinning at the starter but is the engine actually cranking over?
bike wont start. FATTYMATTYUK SV Talk, Tuning & Tweaking 3 04-03-08 07:06 PM
Bike Wont Start Need Some Help Lol! sv650k4 Bikes - Talk & Issues 56 29-01-08 08:17 PM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
bike wont start, HELP PLEASE! silent SV Talk, Tuning & Tweaking 4 08-04-06 05:36 PM
Help Bike wont start tomsmith SV Talk, Tuning & Tweaking 21 09-12-05 10:58 PM
