Old 22-07-07, 09:27 PM   #1
muzikill
muzikill's Avatar
Default Remember that ignition fault i had?
http://www.flickr.com/photos/19218955@N00
As you can see the nice british weather had kindly perished the alarms rubber 'boot' and caused one of the cables to rub against the bike frame through to the wire causing a short and a blown ignition fuse every time it touched!
Needle in a haystack fault finding eh? - no chance of not being able to fix any electrics issues now.
Old 23-07-07, 08:15 PM   #2
Philbo
Default Re: Remember that ignition fault i had?
Such fun isnt it!
Remember Remember the 5th of September fizzwheel Idle Banter 45 08-09-08 01:11 PM
c28 fault kcowgergmm SV Talk, Tuning & Tweaking 5 26-06-08 10:25 AM
Do you know what an F1 fault is? Jayneflakes SV Talk, Tuning & Tweaking 11 07-05-08 07:21 AM
one off FI fault DavieSV SV Talk, Tuning & Tweaking 24 21-02-08 11:08 PM
My fault? Carsick Bikes - Talk & Issues 15 14-12-04 02:30 PM
